The NEW VapoChill LightSpeed [AC]™ represents not only the most powerful CPU cooling system commercially available – its superiority extends to control features, upgrade flexibility, CPU-mounting mechanism, CPU support, emergency shut down features and, especially, LOWEST TEMPERATURES & MOST BANG FOR THE BUCK!
The VapoChill LightSpeed [AC]™ has been optimised for the most extreme performance by using a different coolant; R507, which is the most powerful and effective coolant for CPU heat removal. You will not only achieve the lowest possible CPU core temperatures but also an extreme overclocking potential. Unlike the rest of the VapoChill family the LightSpeed [AC]™ is based on 115/230V why it supports all motherboards.
_zZz_
