Monitor pluged in and rebooted twice and still nothing :shrug:
I used a GTX 570 and 2 GTX 260 C216s without an SLI bridge and 1 monitor and never had any problems running PrimeGrid on them. There was an issue years ago with F@H, but as far as I recall it was fixed in 2009. I ran both 260s on F@H without any issues with 1 monitor.
nice one artemm
Just looking at the stats over at WCG. Might be time for the GPUGrid boys to come home coz to take on the next step up in the dailies will need the team output to more than double. Easynews, however, appears to be history at history point.
Thanks for pointing this out! Now I know that I won't want to use Mint on my new i7-920/GTX470 build. Windows 7 x64 "SE-W-E" it is :up:
Yes. When the GPU WUs were in beta, they were worth ~56 points each, now they're worth ~34. Still amazing, but a bit less so ;)
We need more ATI GPU's running on our team fast :yepp:
I've got an HD6850 I'll get online soonish. I have to reinstall win7 first :(
I will have to do the same ...changing 1 rig to win 7 then changing the accounts around some is how I feel I will do this just now However that is before I run the 775 ddr2-800 rig @3.3 vs the 1155 ddr3-2000 @4.8 test. I still have not put this on a Kill a Watt either but on that at least I am hopeful. I think I have 5 hd 5870's all ready to go...... Should be good to add 70K to my current 25K ppd... I have the slots.... and probably the psu's just need a few more cards if I can afford the power.
It will be the power use that determines if I need to sell these cards and buy newer faster better here
This was a rig (Work PC in sig) that normally would only run 12-14k WCG PPD going 24/7:
Statistics Date -- 10/12/2012
Total Run Time -- 0:001:23:50:53
Points Generated -- 173,573 :D
Results Returned -- 728
EDIT:
Let me know if you are going to sell. I can put one in my Work PC for with free electricity.
So my question on this -how long are the HCC WUs going to last? Are we going to eat them all up then have a bunch of left over GPUs?
Not trying to rain on the parade - just want to know before I start making plans!
And thanks for all the GPU numbers guys! :up: :up: :up:
old_chap, shame your so far away.. I could use another 5870..
460GTX..6.5 mins
5870..4 mins
Oh, and I won't take away anyones joy but Xs did over 20 million yesterday and is looking at 23 million today..
I might even hit a million..Now that is funny! :D
Off to help out a friend..later guys..:up:
I am wondering how the 7750 would do as it uses the same chip as the 7770, only 512SP vs 640SP and 800 MHz vs 1000 MHz compare to the 7770. I could buy 3 (I have an empty socket 1366 board) for the price of 2 7770's and they use almost half the power at full load per card, so 3 7750's should use less power than 2 7770.
I found a post on the WCG boards reporting about 4 min/wu for a 7750.
https://secure.worldcommunitygrid.or...ad?post=395655
It's nice what a shiny new GPU will do.
10/13/2012 0:000:19:34:31 92,855 404 (averaging ~85 seconds per)
<<<replaced a 5450 w/ a 7870>>>
10/12/2012 0:000:14:42:36 4,166 27 (averaging ~30 minutes per)
10/11/2012 0:001:02:47:07 5,325 23
10/10/2012 0:000:01:43:41 438 2
10/02/2012 0:000:02:11:26 1,591 4
The best part is that, from what I remember, it "only" adds about 60W to power usage while crunching. Like a dumb***, I forgot to check the wattage before the switch.
