Originally Posted by
bds71
i don't know - i guess it depends on what results you're after. once i retire (in a couple years) i have always planned on trying to get into the testing arena. i have already been giving thought to certain things i would like to do. for one, i would love to do all my testing with IX - but as has already been stated, it's just not cost effective. so i thought instead of how to have *equal* testing with paste (since, with paste, so many more things can influence the end result - such as mount design/mounting pressure, bad mount (not properly centered), bow shape, amount of bow, differences in batches/bad batches). i think i may have come up with a solution - but that solution still takes the factory mount (partially/mostly) out of the equation and puts all the tested blocks on more or less equal footing. to me, i think that is a more fare (farer???) way to test blocks. but, what i want is to test the effectiveness of the block itself; to see which *block* is better/best rather than which *system* is best (or what company has the best current mounting system). if i understand what you are trying to do: you want to test the "whole package" which includes the mounting system *and* the block (?) personally, i don't think either method is fare or unfair - i just think they are designed to test different aspects of the same item.
