^ are you a writer? if not should be :)
You described fester perfectly (you forgot to mention it was an indoor concert and festicles was wearing dark sunnies too!) :D
TeamAU have had so many sessions and always mention you for the right reasons (and MBeier > for the wrong reasons). We are your biggest fan dude :D, rock on!
hahah Japanese restaurant bench session live (hilarious!)
If I knew the basic tweaks I wouldve set them :D
I played around with it last year when SB was new, but pretty much gave up, forgot the few tweaks I was trying to learn, and went back to old 3d benches. Cant believe how much time can be spend just on this benchmark. Trying the copywaza/cdt thing, my time got worse :eek:, with no cdt I get 6m30s in xp, with cdt getting 6m31s:confused:
My entry is postponed :)
I got myself a chip that wont make 4600mhz stable, and wont pass 1200mhz(cpu-z) ram.... 1000mhz benchable on IMC...
Ivy is really something, I truely agree with DrWho, it is the best thing since sliced bread....... If only we knew how freaking awesome it would be, and not pay attention to all those huge sinners that leaked, and all got sued into hell, ofc.... If only!!! Then the light would be brighter and we would know that these things are better than Chuck Norris on bacon!
Untill I am in your avatar, I dont believe you!!!! Y u hurt ma feelingz?
trans you definatly picked the weird/strangest guy from team au to follow, just look at the guy, its the middle of the night, hes inside and hes wearing sun glasses, not only that, he wasn't happy with the tallest tek9 ever made, he had to put a paper extension on it that makes it 2 inches taller, but strangely there is not even a bigger gap to pour into,
thats just the sort of guy fester is, he does weird :banana::banana::banana::banana: and for no reason, top bloke!
Is there a trick to running 8-11-7 with bbse or is mine all sh1t, 8-12-8
Someone want to list the basic tweaks for a clueless,n00b? :D
OS:
1. For your own sake (unless you know what you are doing), pick a tinyXP OS
2. LSC, Large System Cache
3. Affinity, bind benchmark to a thread, and make it high priority or real time - result is likely to be same, except realtime is more likely to cause crash (in my experience)
4. Cpt. obvious; Disable pause screen :p:
5. Have 2 partitions on the OS, you'll need it for CW (Copy Waza)
The most obvious none OS tweaks are;
Max out ram
Use right BIOS, some motherboards sucks for effeciency, especially the cheap ones.... I cannot recommend GA-Z68MA-D2H-B3 for benching, while the (accept that challenge DINO!!!)
More complex OS tweaks:
maxmem
pagefile
manual copy waza
registry tweaks in generel (I only do ram settings myself in registry...)
msconfig, no - dont do diagnostic... Manually disable all the crap you wont need...
Other tiny tweaks;
16K run a couple of times prior to your actual run..... BUT; A new folder with SuperPi beats that (Sure I am picking a fight with everyone on that...)
--- There are a heck of alot more tweaks, but those are the basics and should be a very decent start for you, also, use OCX Tweaker for Copy Waza, untill you figure how to do it better manually yourself.
@ Hondacity. Would you mind updating the rankings? I know Fugger forgot his details for his submission, but I will gladly do this for him:
Fugger - 6.29.53.1 - 100 x 50 - 4999.91mhz - 1400mhz - 10-13-12-28 - ASUS MAXIMUS V GENE - AIRCOOLING
:p::p::p::rofl::rofl::rofl:
-updated
at least Charles beat zeneffect's 6'33 lol, can't wait for Dave to beat Charles :p
Splave,
The trick for me was finding out the EXACT timings my sticks liked. for instance if tfaw is too loose, then no boot, if trfc is too lose no boot. then there is the issue with the memory dividers.... 2666 no boot even c9... 2600 its happy even when increasing bclk. mabye its my weird sticks, but it seems like you have picky ram yourself.
im running tfaw 20, trfc 97 (2650ish mhz on the memory). if i dont set those 2 settings to exactly that, it wont post or boot. 51 error. im also on a beta bios so that might be part of what im experiencing, however im more inclined to think its an overall combination of factors... board, bios, memory, cpu, overclocker, and ambient temps... more ambient temps than anything else.... i watch molten rivers of lead from my window as demons hop up and down. yes, los angeles is as hot as hell. satan says hi.
@ honda- hey, i improved that time to 6:29! i expect we will see a 6:19 from charles if he continues to use the same sticks.
Does it work alright on TinyXP? I could never get it to run on TinyXP, and it never would start on Win7 64-bit.
I have always ended up doing manual waza, ~1GB, haven't had the time to test different.
When doing copy waza / CDT you need to look at the system cache in Task Manager, it should go way up above available ram...then after it is over, you usually have a wait period of about 30-40s where your free ram will come back up and get closer to your cache, when it stops changing then you run Pi.
GUN'G'STAR - 6:19:313 - 50x100 - 1400 - 10-12-12-21-120-1 - M5G - sams/bch9 - 1,87 - all on air
THANX CORSAIR RUSSIA & ASUS RUSSIA
Attachment 126945
Here's a run i made about a week ago ... still on air .
Stelios - 6:20:172 - 46x108.7 - 1304.5MHz - 8-12-8-24-96-1 - Asus Gene V - Gskill Ripjaws 19200CL9 PI 2xGB - 1.82v Air Cooling
I'm gonna try to get 6:19 ...
Hi all :) can I come in & play with my 3570K?
C-N - 6:25:156 - 50x100 - 1200MHz - 8-10-8-21-68-1 - Gigabyte UD5H - GSkill C8 2133mhz 2x2GB/BBSE - 1.79v - Stock Air
http://i106.photobucket.com/albums/m...2M/6m25156.png
http://i106.photobucket.com/albums/m...5156AIDA64.png
ZenEffect - 6:19:453 49X102 -1326.3MHz - 8 -11-7-25-97-1 - Gigabyte Z77X-UD5H - Gskill Ripjaws PC17000CL8 2X2GB/BBSE - 1.85V - Air cooling
http://i48.photobucket.com/albums/f2...76/619453a.jpg
took a total of 8 hours before tried switching fans to molex adapters instead of off mobo headers... then it passed on the 1st try. odd, but i will take it. will re-test with better waza and mabye timings (if the sticks will allow me now) later. its time to enjoy a very nice sunday.
im waiting for pro to post up and shame us all. this thread is pretty fun :)
Great run! And good that Fugger is back in the first spot with you moving out of the way! How about anyone getting passed by fugger is not allowed to post in this thread anymore?
...I alos like the idea of Fugger vs Dave....like David vs Goliath....and Dave being Goliath....oops
Thanks Mike. If you are in LV, dont forget there is a partial solar eclipse later this afternoon :D
