Some of my samsung won't jump 2900 unless jolted with 1.9V+, vccsa 2.5V and vttddr 0.85V
VCCSA 2.5V? I s sure hope that was a typo Dumo? If not, how many beers for that? :D But only 0.85V Vtt? Vtt=VCCIO right?
vttddr not vtt
Got the F3-2600C10 kit here. 32M @ 2800C10 on M5G with 1.75 vdimm:
http://img.photobucket.com/albums/v2...ps3c796fec.jpg
Very nice Bart but did you really need 1.25V VCCSA? Mine couldn't do that, not even at 1.83V but i didn't try that much VCCSA though, maybe i should have? I can finish 32M at 1400 11-13-13 at 1.71Vdimm though.
Left it @ auto buddy, sets it way too high. Rerunning now with vccsa & io set to 1.1v :)
edit:
http://img.photobucket.com/albums/v2...ps18754f8c.jpg
Nice, thanks for showing. Maybe i should try again with just 1.75V. ;)
edit: Bart, my friend, you're a genious! :up:
http://i.imgur.com/SFstn.png
Sometimes things are so simple that they just get overlooked. 1.75V in bios did the trick. This is in Windows 7 64 bit which is usually a bit harder to get stable than 32 bit OS.
Thanks for showing me the ropes Bart!
It is first run with 1.7V on M5G. i wish for some desent timings 32m.
Attachment 130439
promising 32m result.
Attachment 130474
Promising indeed! Surprised to see you're using bios 1204. Very nice run!
Hmm, so it IS possible to coax 9-11-10 out of CFR at higher clocks, you just have to gorge them with massive voltage lol
1.85V+ @ 2900+ for some cfr kits
Well 1.85v isnt enough to convince my RipjawsZ 2133C9 kit to do 9-11-10 at 1200 mhz lol
8-11-9-16-1T @ 2728 on cold is so nice!!!
[IMG]http://imageshack.us/a/img850/904/capture1sl.jpg[/IMG]
Wait a minute, you're pulling this of with these Trident-X sticks?
That's great kintaro, G.Skill must be binning like mad for these kits.
By the way it's 8-11-9-16. You had me there for a second. :D
Still absolutely awesome for Hynix chips. Never knew Hynix could pull this off. Great stuff Kintaro! I bet you don't dare to tell Vdimm for that. :D
