loud you are scoring alot better than me on the last post, was that win7?
i guess 100Mhz on cpu and better tRAS makes a difference?
i bought these for 40 dollars
http://img5.imageshack.us/img5/3531/696sp32m.png
tRFC was @ 95 iirc
tRFC was @ 95 iirc
@ Owikh...You're all set for SB-E:up:
nice, its always good to be ready for X79!!!!! I am so excited!
Then I hope you are lucky and get same ICs on the new kit as you have on the old ones, if not you will have to improvize :D / same SPD etc is overrated in my opinion anyways^^- same ics are sufficient :)
http://www.abload.de/thumb/8gb160020001070c832ma3h9.jpg
Hoard up all of the PSC you can find.
The prices are going to bounce once BD is out :rofl:
Playing with my old sticks...
2600K @ 5.6GHz
2175.66MHz 6-9-6-20-1T
http://i458.photobucket.com/albums/q...00K/102x55.jpg
2600k @ 5.7GHz
2222 7-9-6-20-1T
all on water, directly booted from the bios.
http://i.imgur.com/PGCQK.png
Awesome clocks there guys:up:
Now save those rams for 2700K or FX8150:D
this is sort of unrelated... Im doing a little pre-testing right now for the before trying more. ive finally figured out how to run the z68xp-ud4 with higher bclk... turns out i was overcomplicating the issue. so far, bclk has exceeded what was capable on the p8p67-pro using the same chip and memory.
http://i48.photobucket.com/albums/f2.../Capture-8.jpg
see what i did there? ;)
this was on green pcb btw if anybody cares. Jan 2011 sticks.
that is abuse! try it with 4 sticks? :D
cant get tighter than 8-9-8 with 4 sticks.
dont like the full blown windows 7 x64 ultimate pi? I dont either, but im tuning here because im lazy like that. i will os change and re-run "later"
efficiency/os doesn't matter, I know you got it already :D
It would be nice to bench 2700K at the same time FX released:D
Awesome clocks :D - board will not limit you in my opinion btw, none of five boards I had did less than 107bclk, with different really bad cpus as I'm out of hwbot for a long time now and have no need to select cpus I take what I get xD. As for 4 sticks, I think we talked about this before, same with me, 8-9-8 with BBSE, better timings are not possible on various boards
typically on air my cpu can only do 104.2 bclk on both asus boards i have and the ud7. z68xp-ud4 ive already passed 106.1 which is .2 higher than what i could achieve on asus while cold... though i need to play with skew options more with m4e.
Same ram and cpu max @ 108.7 BCLK with P67-UD7 and 106ish BCLK on P67-UD7 B3
Time to start prepping for 2700K, hopefully it will be easier this time around:up:
hey guys.. i realize this might not be the place for it, but is it ok to run 1.72-1.74 vdimm 24/7 on sb?
if not then what is the max you guys recommend?
i need it for my hypers :( and my bbse can hold 7-9-7-20 1T 2200MHz with 1.74v also changed tRFC and subtimings for better efficiency
for 24/7 just use the xmp, then jack up the cpu multi to something stable with 1.3volts. easy :D
for 24/7 i do just about the same thing. only diff is, i set cpu multi to 46x, the rest is auto. so... clear cmos, set xmp, cpu multi 46. the board takes care of the rest ;)
then again, honda and I may be assuming too much... you are using a K processor arent you badatgames18?
smart man :D
and mr bad, don't enable pll overvoltage :)
