EVGA GTX 570 SC + Backplate + highflow bracket.
http://img546.imageshack.us/img546/7100/ocbestscore.jpg
ORB: http://3dmark.com/3dm11/1273233
seba84_2005 -very nice clocks !!]
I guess you are not worried about VRMs and that voltage ?
OCP watching my GPU :D
Evga sc full EK .
http://i23.servimg.com/u/f23/12/23/45/17/rec_2012.jpg
For now, my best score:
http://www.abload.de/thumb/thebestof570sliuqsb.jpg
http://img198.imageshack.us/img198/7158/7373.jpg
small news ,probably already posted ;
http://www.hardwarecanucks.com/news/...hd-classified/
great results guys !!!
cheers :up:
Sergio
Nice
I've never used Afterburner with SLI before.
I'm running 275.33 drivers and even if I go into settings and unlock voltage control & monitoring, I still can't bump voltage? What gives?
One other question. How safe is it to voltage bump these cards? I know a lot of people complained about them dying. BTW, I'm running two MSI GTX 570 Twin Frozr III cards.
Without a voltage bump, I can't really go past 810 or so core clock w/o instability. :(
what exactly are u trying to gain by over volting? seriously..are u just trying to achieve a benchmark score? or do u game and want higher fps...cuz im looking at ur specs and ur system is just fine without risking catastrophic failure
Guys short question:
I have two 570's from asus. Both have evga bios ( the same ). And in 3d load one one them has 1.0V and second 0.988V Why ?
http://www.abload.de/thumb/beztytuu47a2.jpg
Just trying to figure out why it simply won't allow it.
Trying to OC the cards at this point is fruitless. 770 core can OC to about 815. Seems really really low.
If the lack of unlocking voltage is due to a driver issue or something, that might explain my lousy OC @ stock volts.
Broke 12K easily. Not bad for a n00b. :D
http://i55.tinypic.com/bvoer.jpg
i7 2600K @ 4.9ghz =H2O
GTX 570s = Air
nice :up:
Excelent work man!
Congratulations!:up:
Thanks guys.
I can pump the memory settings from 2000mhz to 2125mhz and run 3Dmark with tearing and pass, but my score only jumpes to 12270.
I either need to push the cpu well past 5ghz or get a 3rd 570 to break 13000 as these cards won't handle much more of a higher OC unless I voltmod.
Hi all
Long time no go to XtremeSystem
Because secondary 5 is really busy
Well
today I try to oc Inno3D GTX570
This card is really nice and strong
Room Temp : 25 , Standard Stock Cooling
Easy to oc to 1000Core 2300Ram @ 1.088V , really nice
But this moment , only have 1090T@3.8GHz , so rubbish:down:
http://holland.pk/9Xp
Broke 12,500 points. I think I pushed these cards as hard as they'll go w/o volt modding. Pretty happy with my score!
Attachment 117606
Hi guy's
Is 1038mv a save voltage for the evga gtx 570 superclocked. The reason i ask this because with the oc settings the card came i had driver display crashes back to desktop. Upping the voltage to 1050mv solved the crashes and artifacts even playing 5+hours, before that i used 1025mv which wasnt stable. But 1050mv seems to high for my liking. So i changed it to nvidia stock speeds that helped also but i payed for the SC version. So i returned to the factory oc setting that came with the card except i upped ONLY the voltage as seen below:
Core voltage: 1038 Mv (it came with 1000mv)
Core clock: 797 Mhz
Shaders: 1594 Mhz
Mem: 1950 Mhz
So is the above setting with 1038mv a save voltage i know the card has a maximum voltage of 1100mv. But just te be sure i'm asking this to you guy's. I'm aware that lots of people had issues with the 500 serie it, even rma'ing it seems not to solve it in some cases. Seems the oc versions have inadequate voltage imo. This could be fixed with an bios update...? I'm only interested in stability.
ps: Core i7 920(do), evga x58 sli le, 6gb mushkin ram 1600mhz, corsair ax850, watercooled cpu and gpu.
Thanks in advance.
Hi everybody!:)
I have a gtx 570 Palit and I would like to ask: how can I bump the voltage over 1,1v?
Now I can run on clock 950/1100 with 1,1v and I need more voltage to go over 950mhz:D
Thanks in advance!
Here are the results at 950/1100 on 3dmark vantage:D
Attachment 118049
My second GTX 570 arrived today!
The first results on 3dmark vantage and 3dmark 11:
Attachment 118519
Attachment 118520
I think it's good for a start!
I get 10k at full stock in 3dm11:
http://3dmark.com/3dm11/1497479
And 12k with mild oc:
http://3dmark.com/3dm11/1559463
In Vantage I get 34k at stock clocks:
http://3dmark.com/3dmv/3299939
And 41k with mild oc:
http://3dmark.com/3dmv/3340401
full asus full koolance
http://img35.imageshack.us/img35/9889/benchg.png
http://img534.imageshack.us/img534/9398/bench2t.png
nice stob but why the ram in 2T ?
for me , evga sc 570 full EK ,
test with 270.61 :
http://i43.servimg.com/u/f43/12/23/45/17/570_re10.jpg
test with SB driver 275.33 :
http://i43.servimg.com/u/f43/12/23/45/17/vantag10.jpg
with 980x and 275.33 :
http://i43.servimg.com/u/f43/12/23/45/17/lo11.jpg
the best drivers are the 270.61 on vantage and the best on 3d 11 are 275.33
