Rear fan is 92mm, no space for 120mm, that's why I added one to side panel. I send you a PM.
Kind Regards
Regarding the PSU and airflow. I have an idea, that would completely remedy the airflow problem (not saying that there is one but there was one).
If you flipped the PSU to stand on its side, with its fan taking air in from the new fan mount on the side the PSU would always have maximum airflow and effeciency. The hot air from the compressor can then freely pass out from the rear fan and additionally perhaps another fan on the other side.
Something like this: http://www.overclockersonline.net/im...s/install6.jpg
Alternatively the PSU could be placed in the bottom with the fan facing downwards and sealed off.
In any case I would perhaps thermal isolate the PSU chassi. I think the hot air coming from both the condenser and the compressor is considerably hot in comparison to what the heatload a psu usually get from pc components when mounted together with the PSU.
I really love this case - Want one :)
I was thinking about that, but If I place PSU like that there won't be enough space for longer PSU's, because there is compressor. If side panels are on both sides, you can have one fan for pushing cold air inside, on the other side no fan or lower speed fan. I think that would also work.
Kind Regards
well so far: the lil fan under the psu isn't a problem for my psu at all.
had a lil linx 24h run @ 4,5ghz and so on, no overheating issues :)
Keep going!!
Is 5ghz attainable?
well, I'm sure the phase will hold it....but my 965 suxx.
currently working on my sr-2 build....but mb I have time later this week for my lil friend
http://alexiel.stor.li/intel.jpg
that guy will do it ;)
is that a naked 980x?
nah its a naked w3520 but clocks quite high ^^
well atm its watercooled, though I alrdy talked with LD about a phase change for my mountain mods so lets see ;)
Sounds good very good!
Next time you load the system for a little while, could you perhaps be so kind and maybe measure temperatures with a type-k probe (if you have one) around different areas, ie INSIDE the PSU and also what hardware you are using of course.
Thanks bud
Yup, looks nice.
Hehe :D :DQuote:
I was hoping the LD could make a Phase Change for dual processor :up:
henrik
sure, I'll check what I can do for u ;)
;):D
oh and finally...it's time to change the ugly psu cables to better looking ones +it's perfect to hide the koolance qdc :D
http://alexiel.stor.li/LittleDevil/epssleeve.jpg
though....mb I should re-sleeve em white...not sure atm :confused:
WOW!!! Amazing stuff there LD :clap:
If I needed a powerhouse like this, I'd have to order one of those. As it is, I use my i7 920 @ 4.2GHz to surf the net 99% of the time :p:
@ sargatanas....I hope you're planning to put that 4-way board to good use :confused: (um,m, 2 more cards? :D)
well 2x5970s atm so not that bad ;)
I wanted to order 4x5870s or 4x480gtx...not sure so far if I use em for the 4way or my sr-2 (though....might be a bit too much for that lil 480 radiator so we'll see) ;)
oh about the psu:
u could change the psu backplate and use one of these lianli psu extender, I think it gives 6cm more space
kinda like I did it:
http://alexiel.stor.li/v2000/25.08.%20psu1.jpg
http://alexiel.stor.li/v2000/25.08.%20psu2.jpg
sargatanas, its good solution but it ruins the impresion of a case...
LD, great work ! im thinking about buying this case for around a month, but the money is my problem with buying it ;>
Here are some ideas:
-quad radiator solution on a top is a nice idea for this case,
-fan grills on the back of the case would look nicer is the same style as the one on the side to help psu,
-maybe you should think about selling it with water cooling instalation already placed in it, as you would gain customers who are rich and seeking "lash" stuff like lc'ed pc but they have no knowledge or skill to instal water cooling system on their own
ok, have to admit it ruins a tower, though sometimes u dont have another option.
well I wouldn't offer it with watercooling gear equipped. why? well there are so many parts, starting with radiators, reservoirs, cpu blocks and so on and you can't please everybody.
+ ppl will only see the cost of it like: omg this is expensive!
+ it takes some time for LD to install it too, time he probably doesn't have +adding even more costs for his time for the installation
+ if you aren't able to install a watercooling system at all then it's kinda silly to buy one with a phase change too :)
think quad support is alrdy planned iirc. fan grills might be an idea, though it's fine for me, the phase needs as much air as possible and would look strange with this fan grill at the back of it.
my point was that the fan "covers" (dk how to name it) on the back the one next to power supply and the second one next to expansion slots aren't really nice looking,
next idea is to put some removable covers on the expansion slots as when somebody is going to put some uv light in that case ist going to shine like a christmas tree...
Nice pics @sargatanas.
Thanks for all nice comments guys.
Here are some pics to see how fan is fixed.
http://ld-phasechange.com/images/Lit...ases/fan/1.JPG
http://ld-phasechange.com/images/Lit...ases/fan/2.JPG
Shipping protection :up:
http://ld-phasechange.com/images/Lit...ases/fan/3.JPG
Kind Regards
And one more
http://ld-phasechange.com/images/Lit...C_Cases/31.JPG
Kind Regards
For all EVGA SR2 users, take a look. :up:
http://ld-phasechange.com/images/Lit...ases/SR2/3.JPG
http://ld-phasechange.com/images/Lit...ases/SR2/4.JPG
http://ld-phasechange.com/images/Lit...ases/SR2/5.JPG
Kind Regards
