okay thx.
this is my settings for 3485Mhz:
MB Intelligent Tweaker(M.I.T.)
CPU Clock Ratio............................: 21
CPU Frequency .....(Mhz)...................:3.485
Advanced CPU Features [Press Enter]
Intel(R) Turbo Boost Tech.................:[Disabled]
CPU Cores Enabled...........................:[All]
CPU Multi Threading.........................:[Enabled]
CPU Enhanced Halt (C1E)..................:[Disabled]
C3/C6/C7 State Support...................:[Disabled]
CPU Thermal Monitor........................:[Disabled]
CPU EIST Function...........................:[Disabled]
Bi-Directional PROCHOT.....................:[Enabled]
QPI Clock Ratio*...............................:auto
QPI Link Speed* ...............................(Ghz):6
Uncore Clock Ratio.............................:x21
Uncore Frequency..............................(Mhz):3500
Isochronous Support.........................:[Enabled]
Virtualization Technology...................:[Enabled]
>>>>>Standard Clock Control
Base Clock (BCLK) Control*.................:[Enabled]
BCLK Frequency (Mhz)*......................:166
Extreme Memory Profile (X.M.P.)............:[Disabled]
System Memory Multiplier (SPD).............:[10.0]
"Memory Frequency (Mhz) 1066 1667"
PCI Exxpress Frequency (Mhz)...............:[100]
>>>>>Advanced Clock Control
CPU Clock Drive (mV).......................:[800]
PCI Express Clock Drive (mV)..............:[900]
CPU Clock Skew (ps)........................:0
IOH Clock Skew (ps)........................:0
Advanced Memory Settings [Press Enter}
Extreme Memory Profile (X.M.P.)............:[Disable]
Performance Enhance........................:[Standart]
DRAM Timing Selectable (sPD) ..............:[Expert]
Channel Interleaving.......................:6 [auto]
Rank Interleaving..........................:4 [auto]
>>>>>Channel A Standard Timing Control
Cas Latency Time.............................:9
tRCD.........................................:9
tRP..........................................:9
tRAS.........................................:27
>>>>>Channel A Advanced Timing Control
tRC..........................................:36
tRRD ........................................:4[Auto]
tWTR ........................................:4[Auto]
tWR..........................................:8[Auto]
tWTP.........................................:19[Auto]
tWL..........................................:7[Auto]
tRFC.........................................:60[Auto]
tRTP.........................................:4[Auto]
tFAW.........................................:16[Auto]
Command Rate (CMD) ..........................:1
>>>>>Channel A Misc Timing Control
B2B CAS Delay................................:-[Auto]
Round Trip Latency...........................:64[Auto]
Channel A Turnaround Setting [Press Enter]
>>>>> Channel A Reads Followed By Reads
Different DIMMs..............................: [Auto]
Different Ranks..............................: [Auto]
On The Same Rank.............................: [Auto]
>>>>> Channel A Writes Followed By Writes
On The Same Rank.............................:[Auto]
Advanced Voltage Control [Press Enter]
>>>>CPU Voltages
LoadLine Calibration.........................:[Level 2]
CPU Vcore....................................:1.22500v
QPI/VTT Voltage..............................:1.175v
CPU PLL......................................:1.80v [Auto]
>>>>>MCH/ICH Voltrage
PCIE.........................................:1.50 v[Auto]
QPI PLL......................................:1.10v[Auto]
IOH Core.....................................:1.10v[Auto]
ICH I/O......................................:1.50v[Auto]
ICH Core.....................................:1.10v[Auto]
>>>>>Dram
DRAM Voltage.................................:[1.640v]
DRAM Termination.............................:0.750v[Auto]
Ch-A Data Vref...............................:0.750v[Auto]
Ch-B Data Vref...............................:0.750v[Auto]
Ch-C Data VRef...............................:0.750v[Auto]
Ch-A Address Vref............................:0.750v[Auto]
Ch-B Address Vref............................:0.750v[Auto]
Ch-C Address VRef............................:0.750v[Auto]
