Damn this is an impressive build. Too bad about your carpal tunnel, if I lived near you I'd bring a case of beer over and do all your sleeving for you!
Keep at it, you'll get there :up:
Tossed out custom cables ki made they were crap. Just sata sleeving the gpu power cables now. should have some new pics tomorrow.
Sent from my X10a using Tapatalk
Good luck with finishing that rig bro! I know how tuff it is with the carpo tunnel.. Been there many years ago with having that big time in both hands! Was like being paralized. Could'nt do crap for many many months. Depression and everything set in just cause of that. No fun and i would'nt wish that on my enemies!
Had it again in one hand for the past few months while building my rig.. I believe its brought on from alot of stess. Took months before i could feel my last 3 fingers on the right hand which finally i can.
Heres my build which i finished somewhat a month or 2 ago. Still have yet to find time to finish the lighting.. have the new lights just gota install them. heh.
No Tomorrow Rig
Ok damn I think you Stole My overkill title , 6 pumps quad sli ... nice....
So i dropped about 500-600 with nils ... I probably tossed out and or destroyed 60% of it messing up ... I manged to sleeve my soldered fan cables but not that well but to much work to redo .
made customer gpu power cables and screwed those up .
So I finally gave up and did quick and dirty Sata sleeve on them.
https://lh3.googleusercontent.com/_8...6/DSC_0377.jpg
https://lh3.googleusercontent.com/_8...0/DSC_0384.jpg
https://lh3.googleusercontent.com/_8...0/DSC_0386.jpg
Once I get the 2 eps 8 pin and MB 24 pin done gona route and clean them up.
Then its time in install a Floating panel on the bottom to hide all the cable runs I'm not happy with.
I figure for my birthday or something i'll get the wife to let me order a bunch of cables from martin at http://psychosleeve.com/
Something I forgot to add you could get the sata heatshrink to seal perfectly on the ends of the gpu plugs.
But that requires you to small heatshrink each cable end like you were doing single sleeve, before you put on the sata to increase bulk and give the sata sleeve a tacky surface to stick to.
Too bad I ran out of small heatshrink.
One of my mistakes but perfect example of what i'm talking about.
https://lh5.googleusercontent.com/_8...0/DSC_0389.jpg
:) Thanks!
Hey, can always do what i've done and that just buy extensions that already come modded with single cable sleeved.. http://www.performance-pcs.com/catal...c157454c1be115.
Even microcenter carries them if there local to you..
Though i had to re-sleeve the ones i bought cause they didnt have the right color i needed locally and was in a hurry.
Figured it was alot easier to buy extensions and single cable sleeve them then doing the whole P/S which i did'nt want to void warrenty and its a good thing cause i already had to RMA that power supply.
Honestly sleeving them all together is alot cleaner then how i did it with a wall and a half of cables in the way of the graphics cards.
Doing the above would be perfect for someone with carpo tunnel! :)
Ya, but I wanted to try. All my cables are the same as your exts due to being a completely modular ps an ax 1200.
If I buy extensions it'll be off martin he's a master. And with my setup I can just use 18 inch ext as my main cables PS is centrally located du to custom cut panels. Just have to Change one end to fit the Corsair one for my psu.
wow lookin good
I'm thinking of removing all the sleeveing from most of my system, I have the Atx PS cable bare now and honestly it looks better in my system then the sleeve.
examples
https://lh6.googleusercontent.com/_8...6/DSC_0391.jpg
Just need a good clip /tidy solution
Single sleeveing is not going to happen period. every time i try i mess up my hands for a week.
I was looking at the texture, look against the rest of my case. The fabric look of the sleeveing is working for cables ( allready single sleeved) running the fans but for the MB pci-e and Eatx and 24-pin its going bare black. the sata sleeve solution i have on there now not working and single sleeve doen't look that good either in midair.
necro REZ!!!!!!!!!!!!!!!!!
So just an FYI , the overkill beast is going up for sale, Moving and can't fit it in the new condo along with the baby that's coming along ;-).
Its in the Toronto ON, Canada area
Also I have a ton of modding stuff that a free giveaway... small stuff and odds and end a grab bag if you will if anybody wants I rather a modder from here get it then anybody else.
message me on here with any questions.
*On a side not I know the internals probbly won't sell I have a plan to Do a bookcase build with them LMAO.
The Kits is up for sale, I'm keeping most of the WC, stuff just due to i don't think i could get a good price for it.
Mountain Mod Extended Ascension with custom back panel
internals
