No that's a manufacturing error. I believe all blocks have that. It doesn't decrease performance :). And why would you want to change a block that's already the best one out there? You'll only be downgrading.
Has "downgrading" been proven in a direct head-to-head test? From what I've seen, the EK performs as good as the XT and maintains higher flow rates.
They're called impingement jets. They work something similar to what you see with an open hose vs. a hose with a sprayer on it. The open hose may flow more water but at a lower "pressure" while the sprayer, while somewhat reducing flow, increases the pressure of the water striking the block.
And it's creating turbulence in the block. Low turbulence equals lower performance, higher turbulence equals better performance......more water has the chance to actually touch the block's surface so there may be the chance of enhanced heat exchange with increased turbulence inside the block.
yeah, the only test I saw that scamps referenced earlier in this thread showed them performing same temp wise, ie within 0.2C or within margin of error (one block tested higher on one setting, other on other, basically blocks are so close margin of error exceeds difference).
Though Alexandr0s may have seen some other testing and perhaps would like to share?
And for those saying data does not make sense because at 3.2 one was .2C better, and at 3.6 other was .2C, along with couple other tests switching places with 0.2 margins... actually just looks like honest data to me coupled with margin of error of few tenths degree C (which is true for anyones testing) exceeds difference in 2 blocks in their tests.
Any plan on selling this block nickel plated version, Eddy? :)
Just sold my Heatkiller 3.0 to buy this block :D. Not for the performance, but just for the fact that its EK and it looks cool.
What I was trying to say: He has a block that cost about 80$. From what I've seen was that the EK performs very similar to the XT. I was wondering why he wanted to change to another block, while he already has an amazing block. It's not like now that EK released a new block the XT isn't interesting anymore. It's still an extremely well performing CPU block.
Like to see comparision against Apogee GTZ.
the gtz is really good based from gabe's conclusion
http://www.xtremesystems.org/FORUMS/...d.php?t=226455Quote:
OBSERVATIONS AND CONCLUSIONS
Given the precision of the CPU DTS (+/- 1ºC) these test results are accurate at +/- 1ºC. We can observe that GTZ and HK3.0 are tied, and that 350AC is visibly trailing behind
yeah but gabes results dont mirrors vapors. :rofl:
http://vapor.skinneelabs.com/i7/Roun...impleTemps.png
Can anyone confirm a copper version of the EK-Supreme HF, it seems recently EK has lost it's copper love, just an FYI Mr. Eddy there are people out there who prefer pure copper to nickle.
What exactly is the difference between copper and nickel anyway? I mean doesnt copper have better heat conductivity? So why put nickel there :confused:
A full copper block is in development. It will have little diferent looks than plexi and acetal...
Due to lack of material needed for copper top (the specific dimensions and delivery time) the block will not be ready till end of February. But hoping to make it ASAP.
But still what's the difference? :D Only thing I can think about is that it looks cooler... but it's not like you will see it anyway after you mount it :eek:
yes its all about looks. Yes it looks hot. I have a window, you should install one ;)
http://img6.imageshack.us/img6/627/lianlifinish018.jpg
A bit OT, but I agree with above, and
3. I love the look that people give you when you say you have water in your computer.... And my wife cannot understand why it takes longer to put together the cooling together than the actual computer....
Eddy, love the new block, and love all the options, cannot wait to see a white one up close.
