Originally Posted by
Farinorco
If those specs are correct, I don't know how can they say that power consumption is going to be higher than 300W. HD4870 TDP is higher than HD5850 one, and HD4870 was lower than 300W. Since HD5970 seems to be a dual Cypress GPU with HD5850 clocks, I wouldn't count with a higher than 300W TDP even with the 10% extra SPs and TMUs... of course, it could be for different reasons, and we can't know it yet, but I don't understand why they say that is "probable".
On a side note, I hadn't seen the size of the card previously (13.5" = ...34cm??!). I find it excessive. The ATX form factor is 9.6" (24.4cm) wide, and the extended ATX is 13" (33cm). I really think that videocard manufacturers should stick to ATX measures for the core of their line up, and up to E-ATX for some enthusiastic products that may need it. Nowadays, most high end videocard solutions are E-ATX (even when they don't measure the whole 13", since they surpass the ATX form factor). But surpassing the E-ATX form factor is unacceptable, in my opinion. There is no case to hold it except by chance, not even E-ATX cases (it could fit, indeed it probably will, but it doesn't have to). That's absurd, IMO. :down:
