Yes, it will.
Every i9 will work in all LGA1366 boards after a BIOS update.
It works..........BUT..........."Huston we have a problem".... :(
Take a look at the below benches and tell me what do you see?...... :(
http://www.hipro-tech.com/images/hip...443MHz_png.png
Super-Pi 1M at 3060MHz (if I remeber well) BOTH i7 and i9
i7 = 13.000s
i9 = 13.400s
I assume (well: hope) this will be solved with newer bios releases?
George, try your Gulftown on 762:D
If I remember well at ADW you did a 32M run at 6300Mhz+ with Gulftown on E760 and you get as a result 6.05.XXX. The same with Andre at 6100Mhz...BUT he is benching with E762....:)
Hope the same massman:D
seems E760 bios have some problem with cache.. hope will resolve soon :up:
I didn't compare performance with E762 and E760. I think it's not bios problem. Maybe it's old stepping gulftown problem, such as CO and DO i7.:confused:
Hopefully that is a BIOS issue. Good thing these chips scale another GHz over Bloomfield otherwise this would be a huge dampener. Let's cross our fingers that it is a BIOS inefficiency and can be worked out.
Just in case you haven't figured it out, the i9 is slower clock per clock.
Andre, thats totally insane. Great job :up:
Gulftown will give us the revolution ;)
Hi, can you say me what will be the price of gulftown?
Hellmann
999$
You have 6 months to find bucks before i9 come to market.
Petri, George didn't tweak it at all. He just ran it in order to see what the processor is capable of.
Official 9.10 driver for high score vantage is coming out.
Here you go.
Vista/Win7 64bit
http://game.amd.com/us-en/drivers_ca...common-vista64
Vista/Win7 32bit
http://game.amd.com/us-en/drivers_ca...common-vista32
Win XP
http://game.amd.com/us-en/drivers_ca...=xp/radeonx-xp
Andre can you show me tri fire vs quad fire results. in 03
or any 3dm bench
anyone, buler???
Guys where you got gulftown? -_-
I will compare with 3 cards and 4 cards for 03 as soon as possible.
Nice, Thanks man
looking at hwbot the 4 way and 3 way scores seem to be the same!
i should have the equipment to test next week
Something doesn't seem right with your 3x test Andre. It seems bugged low, even GT1 is very low for 4.58GHz.
