nice works guys :yepp:
im using a k9a2 plat v1, do you guys know how i can adjust the NB multi, in my bios (which i think is v1.5 or 1.6 im not at home and i dont remember) i dont currently have any way to tweek that, is there an app that will possibly let me adjust it, or a bios that opens that option up?
my new one record with AIR :)
-finally, under 16.6s 16.593s
http://img9.imageshack.us/img9/7573/...hz16upload.jpg
How much is RAM speed playing a factor in superpi times here? does having DDR3 help?
what will be better in supepri 1M? CPU 4100MHz, 2870MHz NB, RAM 1093MHz or CPU 4141MHz, NB 2828MHz, RAM 1077MHz? I want to broke my record post in my last post....But think, i cant get to 4160MHz...
CPU speed will count most, NB at 2870 or 2828 won't make that much of a difference, just like ram speed. Just try to have the timings as tight as possible.
FlanK3r, what kind of temps were you dealing with at boot? I'm noticing if my BIOS HW monitor says 37c or up, I have problems booting into windows. :\
I dont know :). But in idle in windows, i have normally 36 C with defaults and with high OC (1.488V and 4GHz or more) about 43-45
Well I was able to reach 16.688s @ 4.1GHZ
http://sites.google.com/site/apokali...i1M@4.1GHz.PNG
I had my RAM at 1:2.66, 5-5-5-15, 2.2V.
you think it would be better at 1:2, 4-4-4-12?
i don't think that will improve your score much but you'll only know when you try.
Do you really need 1.6Vcore for that? Most Phenom II cpu's max out somewhere at 1.5-1.55V or even lower.
I tested yesterday some superpi 1M in x86 and in x64 and i found overall in x64 OS better score! Diferent is about 0.06s.
16.594 @ 4160MHZ (208x20), using 1:2 RAM divider @ 4-4-4-12
http://sites.google.com/site/apokali...pi_4160MHz.PNG
OK, time to revive the "DEAD THREAD" :D
OK, I worked on this chip for a couple days and I think I hit the wall @ 4.5Ghz with 1.58v @ -67c. 25 minutes prime stable then I stopped it and was able to pull a 15 second superpi run and get a validation with cpu-z! BTW, this is a Phenom II 940 plugged into an ASUS M3A79-T..
I know it isnt any where near the best or even close but what the hell! :up:
CPU-Z validation
Some pics:
http://i120.photobucket.com/albums/o...605_163613.jpg
http://i120.photobucket.com/albums/o...605_163531.jpg
http://i120.photobucket.com/albums/o...1b/15secpi.jpg
Nice! Now gun harder!
Get that ram and NB clocked.
Here is my DICE result from some time ago
http://i74.photobucket.com/albums/i2...erPi1mDICE.png
Heres my 940
http://i271.photobucket.com/albums/j...1/pi4261-1.jpg
that was during the winter in January
and heres 32m
http://i271.photobucket.com/albums/j...771/pi32m1.jpg
DDR2
hello guys i can To take part with my 550Be:p:
http://img23.imageshack.us/img23/8065/16218.jpg
here 2M with my best NB, i Forget 1M at 3122mhz NB frecuency:
http://img188.imageshack.us/img188/9701/38797.jpg
now sub 16 with 4250mhz
http://img196.imageshack.us/img196/6899/15969.jpg
:D
very nice! whats your board and cooling?
FINALLY. It took some goddamn low ambient temperatures. And that is why I thank Canadian winter.
http://i74.photobucket.com/albums/i253/Wop11/15657s.png
Whauuuu, congratulations, with AIR cool! What temps? :) U have higher 1M clock than my max validation :D
