Hehe, well this made 1200 really, really easy.
http://img6.imageshack.us/img6/3125/img1390v.jpg
Got a first score...
Tweaks: D3D, LOD set for each test, my run order
88863
http://oc-x.de/bench/3D01-88863.jpg
stummer i believe the bug driver is not allowed since you have to upload to orb, dont know if they accept it tho!
Cool, NICE scores guys
Dean, awesome stuff :D
Learning to bench VGAs, I got this on stock GTX280:
http://xs137.xs.to/xs137/09125/lowclk_stockgpu247.jpg
Taking it under dice tomorrow, I hope I'll learn something from you 3dm01 gurus
xoqolatl, don't waste your dry ice.
You won't be able to reach 1200fps Nature on the i7 @ 4.2GHz, if you have a Core 2 CPU, use that instead ;)
I only have i7 available ATM. Anyway, dice is cheap and it won't be wasted if I learn something in the process, right?
Hopefully I can organise a VGA for this comp before it ends, at the moment all I have with me is an 8600GT, not going to get 1200FPS nature with that. :P Need to harass the boss. :D I wish we could get some comps like this happening locally, we used to but they died out. Would be sweet if we could get a monthly comp like this in all major 3D benchies, maybe get some prizes sponsored etc? Worth lookign into i rate. :)
Small question as it's been a long time since I've ran 3d mark01.
How are you going to check the cpu speed ? I guess you start 3d mark ar 4.2 Ghz, fire it up trough a clockgenwise program to 6 Ghz, and then for the screenshot turn it back to 4.2 Ghz ?
yea we have 2001 eyes, we can easily see which test has been bugged ;).
because a card at stock wil score like 300 CH, then on 1000 core it will score 318 ish car high, so not boost almost from vga, if u up cpu we will see.
Well this weekend my card maxed out -125c and 1175 core for a brief nature, got me 1080 nature, which isnt enough :(. im guessing a 1250 - 1300 card would get it, or if i ran on rampage. But yea the gts 512 can def win this comp if you have a good one. Im out for single card. But i will talk about my 790i 2x gts 512 later :). They reach 1400 fps nature EASY ;)
Cool.
on OT note, finally reached top 100! #97 :D!
okay im back on c2d and ready for some 01 fun :D
first result, not really tweaked but low CH bug is still a problem with 295s, do we have a solution for that? ive tried 185.20 beta driver but all the same
http://img207.imageshack.us/img207/7166/90346.png
no solution yet achil :(
we must mail nvidia!
Took my GTX280 under dice today.
I had to pop the lid to tame the temps:
http://dl.getdropbox.com/u/55589/polsilver_powered.jpg
Final product of my tweaking:
http://xs537.xs.to/xs537/09126/max01...k_88073384.jpg
Bottom line: I have lots to learn :)
I think a skilled tweaker with 1100+ on GPU core could do 1200 nature.
That's true.
Only 880MHz GPU with Dry Ice man ?
Are you using a very very very bad pot or something ? Or just being conservative regarding your GPU's voltage ? :D
I never had to remove the IHS of a GTX 280, no need to.
+1 for having the guts to do it though ;)
Unfortunately, there's a "barrier" in Nature that you can't cross without raising the CPU & UnCore frequency quite a lot.Quote:
Originally Posted by xoqolatl
Nothing helps going higher.
Tweaks that give me 50fps more ? Nothing
Higher GPU clocks ? Nothing
I'm using the best pot there is, TEK-9 4.0 :)
Thing is my card is half dead. It was dead when I got it; I transplanted half of PWM circuitry from another dead card and it came back to life, but it heats like a furnace now. Voltages up to 1.44V didn't help, I ran into OCP or just core crashing with more volts.
hi!, here is a crappy score with crappy p45 mabo :p: i wish i had pcie powa :shakes:
http://img13.imageshack.us/img13/327...0101150515.jpg
Nice work so far everyone! Guess I should put up some kind of leader board or something. These threads go a long way in getting 01 scores up to snuff, doesn't matter what HW you use.
hm...my first test with 9800GX2 on -40C at low clocks 918/1105 :D
PCIe 125 MHz, last the Nature.
http://service.futuremark.com/compare?2k1=9480417
awesome work gprhellas , you did a great job huh , the gx2 aint bad neither ...
keep pushing it
89501 GTX260
http://service.futuremark.com/compare?2k1=9480534
http://img257.imageshack.us/img257/9338/89501.jpg
Best I can do so far on the GTX295 is 91K, need to go cold to get to 1400fps cap, and theres one small issue with that.
