It's going to be ok.
The SPD doesn't dictate the Voltage applied to the RAM by the BIOS, no need to worry.
My bad, need to update sig, running a 790I now with DDR3..
Nostromo
Where are the error codes for this nifty LED Debug display? I checked the online manual and the website and haven't found them. Would they be in the hard copy manual?
Here you go (Thanks for the list Peter Tan):
Award & Intel Debug Codes:
The most common Debug codes, what they mean, and how to work with them.
This Guide is intended for the Foxconn Blackops board, but the codes should be identical or very similar on all Mainboards with Award BIOSes.
If your problem isnt described in this list or the tips listed here dont help you, send a private message to Lardarse or me, or contact the Foxconn tech support. Before you do so, please search the foxconn section here on xs to see if anybody else has the same or a similar problem and post in that topic/thread or open your own topic/thread.
no LED all fans spinning
If the Board powers on with all fans spinning and all LEDs running but the DEBUG display doesnt display any POST codes and nothing else happens, then the PWM probably cant get enough juice. Check if the 8Pin 12V plug and the 24Pin ATX PSU power plugs are plugged in properly, make sure they dont bend too much or haven a lose cable. Check another PSU if possible. If nothing helps, power off the mainboard, remove both BIOS chips and wait a few minutes, then put them back in and power the mainboard on again. Make sure the BIOS chips are seated the right way around, the marks on the chips should face downwards.
FF then reboot
If the Motherboards powers on, displays FF for a couple of seconds with all fans spinning and the LEDs working and then restarts, the Motherboard is trying to detect the BIOS and read from it. This sometimes happens randomly when overclocking the mainboard, but if it happens several times in a row make sure the BIOS chips are seated properly and the right way around, the mark on the BIOS chip needs to face downwards. Another possible problem is that the BIOS is messed up as a result of a too high overclock or a bad BIOS flash. Power off the mainboard, remove both BIOS chips and wait a few minutes, then put them back in and power the mainboard on again. Switch the BIOS chips around or change the BIOS select jumpers to boot from the other BIOS chip in case the initial one is corrupted.
Note that the FF code is also used by the memory configuration and testing procedure, check the POST Code description for A0 and following for details
FF hangs with all fans spinning
If the Board powers on with all fans spinning and all LEDs running and the DEBUG Display hangs at FF, then the board is either working fine but you cant see it, or the boards BIOS is messed up. First hit the Num Lock and CAPSLOCK keys on your keyboard and check if the respective LEDs on your Keyboard turn on and off when hitting them.
A) If they do, then the System is working but you cant see anything on the display for some reason. Check if there is something wrong with the Videocard, the PCIE slot or BUS, the Monitor or monitor cable. Turn the Monitor on and off, switch the Monitor cable from one D-SUB or DVI plug to the other in case your Videocard has two. If this doesnt help then reboot and load the optimized defaults. If that doesnt help either try another Videocard if possible, or try the Videocard in another system to make sure its working properly. Try another monitor or try the Monitor on another System.
B) If they dont, then the System is stuck at the very early initializaton phase. This could mean that the BIOS is messed up or there is something wrong with the Mainboard or CPU. Turn off the board, remove both BIOS chips for a few minutes, then put them back and power the board on again. Switch the BIOS chips around or change the BIOS select jumpers to boot from the other BIOS chip in case the initial one is corrupted. If this doesnt help either contact me or Lardarse of the Foxconn tech support.
If this didnt help then make sure the CPU isnt missing , is seated properly and not damaged. Check the CPU in another board or check another CPU in this board to make sure the CPU is fine. Check if the cpu is seated properly and the pads and pins are clean and make good contact with each other, and make sure the socket is fastened well and the heatsink is seated properly.
FF with beeping
If the Mainboard powers on with all fans spinning and all LEDs running, but the Debug LED shows FF and you hear some beep codes, check if there is something wrong with the Videocard, the PCIE slot or BUS, the Monitor or monitor cable. Turn the Monitor on and off, switch the Monitor cable from one D-SUB or DVI plug to the other in case your Videocard has two. If this doesnt help then reboot and load the optimized defaults. If that doesnt help either try another Videocard if possible, or try the Videocard in another system to make sure its working properly. Try another monitor or try the Monitor on another System.
2b
When the system powers on and the Debug LED shows the usual POST code sequence but hangs on 2b or you get a beep code as soon as the sequence reaches 2b, then the Mainboard cant detect your Videocard properly. Note that the POST code sequence might not halt at 2b but continue, so the final POST Code it displays could be FF, 1E or 7F which means the Maiboard booted, entered BIOS, or OC recovery kicked in and is waiting for Input to enter BIOS. Since the Videocard couldnt be detected properly you will only see a black Monitor and either 2b, FF, 1E or 7F. Check if there is something wrong with the Videocard, the PCIE slot or BUS, the Monitor or monitor cable. Turn the Monitor on and off, switch the Monitor cable from one D-SUB or DVI plug to the other in case your Videocard has two. If this doesnt help then reboot and load the optimized defaults. If that doesnt help either try another Videocard if possible, or try the Videocard in another system to make sure its working properly. Try another monitor or try the Monitor on another System.
7F
When the system detects that a critical error happened during the last boot attempt or several boot attempts failed, so OC recovery kicked in. There should be a message displayed on the Display informing you that OC revocery kicked in and that its waiting for your input to enter BIOS. If you cant see this message cause your Display stays black, please check the description for POST Code 2b.
1E
Your in the BIOS right now, if you cant see the BIOS cause your Display stays black, please check the description for POST Code 2b.
E0
When you get this error message the Mainboard cant detect the memory SPD, the memory itselft, or there was some problem while reading from the SPD. Shut down the Mainboard and make sure the memory is seated properly. Load the optimized defaults, if this doesnt help then try one stick of memory in slot1 or slot2, if possible update the BIOS, try another SPD on your memory, try another set of memory or try this set of memory in another system.
E1
Virtually the same as E0, check E0 for a description.
C1
If the Mainboard hangs during this bootup phase then its most likely a memory related problem. Please check the settings your tried and load the optimized defaults. Check if the set of memory has been tested by us or any other user, search for topics/threads in the foxconn section about this set of memory to see how other users are configuring it. During this phase of bootup the Level 2 cache is detected as well, if the CPU is overclocked or damaged or misconfigured it might trigger this POST Code as well. If the problem doesnt seem to be memory related for you, then search for topics/threads from other users who are using the same CPU and check how they are configuring it. If possible check another CPU in this Mainboard or check the same CPU in another Mainboard to make sure its running fine.
A0 and anything from 03 until 91
If you get any of the above POST codes it means the initial memory configuration and testing procedure failed. Check if the set of memory has been tested by us or any other user, search for topics/threads in the foxconn section about this set of memory to see how other users are configuring it. Check the detailled POST Code list below for more details on he memory configuration and testing proecures POST Code sequence.
54 with beeping
This POST Code is a part of the above initial memory configuration and testing Codes, but If the Debug LEDs display 54 with a lot of beeping, it might be something else. When you apply new settings in BIOS and hit save and exit you might get this error. It doesnt NECESSARILY mean that the settings you tried to apply dont work. Keep the power button pressed for 4 seconds to shut the board down - wait 10 seconds - then power the board on again. OC revocery will kick in, enter BIOS but just hit "save and exit" and see if the settings work now. If you get error 54 with beeps again the settings your trying wont work, most likely cause the memory cant take it. Check if the set of memory has been tested by us or any other user, search for topics/threads in the foxconn section about this set of memory to see how other users are configuring it.
A1
If you get the above POST code it means the initial memory configuration and testing procedure passed, but there was a problem when setting up the clockgen and the system clocks. Check your system settings, load the optimized defaults, if these tips dont help search the foxconn support section for topics/threads about the same or similar hardware you are using.
C5
When your system hangs and the Debug LEDs show C5 your memory or the chipset is most likely not stable at this setting.Check if the set of memory has been tested by us or any other user, search for topics/threads in the foxconn section about this set of memory to see how other users are configuring it.
80
80 or FF are the codes the board shows under normal operation.
Detailled list of Award BIOS Port80 and Intel X38/X48 POST Codes:
These POST Codes are generated by the Award BIOS Kernel Core using the Port80 feedback from the CPU.
Note that some of the Intel Chipset memory configuration and testing procedure Codes (BLUE) are identical to some of the Award POST Codes. The BIOS cannot translate those Codes and just forwards them, but from the context it should be clear what a Code means even if there are two possible interpretations.
no LED all fans spinning PWM cant get enough juice
FF Test CMOS R/W functionality (FF is used for several steps, see further down in the list)
CA Base memory Test
CB Base memory Test fail/error
CF Test CMOS R/W functionality
C0 Early chipset initialization, Disable shadow RAM, Disable L2 cache, Program basic chipset registers
C1 Detect memory, Auto-detection of DRAM size, type and ECC, Auto-detection of L2 cache
E0 Cant detect SPD/memory
E1 Cant detect SPD/memory
A0 memory configuration and testing
03 Intel memory configuration and testing code
24 Intel memory configuration and testing code
26 Intel memory configuration and testing code
27 Intel memory configuration and testing code
FF Intel memory configuration and testing code
28 Intel memory configuration and testing code
29 Intel memory configuration and testing code
30 Intel memory configuration and testing code
31 Intel memory configuration and testing code
32 Intel memory configuration and testing code
33 Intel memory configuration and testing code
34 Intel memory configuration and testing code
35 Intel memory configuration and testing code
36 Intel memory configuration and testing code
37 Intel memory configuration and testing code
38 Intel memory configuration and testing code
39 Intel memory configuration and testing code
40 Intel memory configuration and testing code
41 Intel memory configuration and testing code
42 Intel memory configuration and testing code
43 Intel memory configuration and testing code
44 Intel memory configuration and testing code
45 Intel memory configuration and testing code
46 Intel memory configuration and testing code
47 Intel memory configuration and testing code
48 Intel memory configuration and testing code
49 Intel memory configuration and testing code
50 Intel memory configuration and testing code
51 Intel memory configuration and testing code
52 Intel memory configuration and testing code
54 Intel memory configuration and testing code (54 with beeping, check detailled description on the top)
81 Intel memory configuration and testing code
82 Intel memory configuration and testing code
84 Intel memory configuration and testing code
90 Intel memory configuration and testing code
91 Intel memory configuration and testing code
A1 Finished Intel memory configuration and testing code, going into ClockGen
C3 Expand compressed BIOS codes to DRAM
C5 Call chipset hook to copy BIOS back to E000 & F000 in shadow
03 Initial Superio_Early_Init switch
05 Blank out screen, Clear CMOS error flag
07 Clear 8042 interface, Initialize 8042 self-test
08 Test special keboard controller for Winbond 977 series superIO chips, enable keyboard interface
0A Detect PS/2 mouse/keyboard
0E Test F000h segment shadow to see whether it is R/W-able or not. If test fails, use onboard speaker alarm
0h Expand the Xgroup codes locating in pysical address 1000:0
10 Auto detect flash type to load appropiate flash R/W codes into the run time area in F000 for ESCD & DMI support
12 Use walking 1's algorythm to check out interface in CMOS circuitry, Set real-time clock power status, and then check for override
14 Program chipset default values into chipet. Chipset default values are MODBINable by OEM customers
16 Initial Early_Init_Onboard_Generator switch
18 Detect CPU and Cache, (initialize L1 Cache?)
1B Initial interupts vector table. If no special specified, all H/W interupts are directed to SPURIOUS_INT_HDLR & S/W interrupts to SPURIOUS_soft_HDLR
1D Initial EARLY_PM_INIT switch
1E Finished Loading BIOS Menu
1F Load keyboard matrix (notebook platform)
21 HPM initialization (notebook platform)
23 Check validity of RTC value: e.g. a value of 5Ah is an invalid value for RTC minute. Load CMOS settings into BIOS stack. If CMOS checksum fails, use the default values instead. Prepare BIOS resource map for PCI & PnP use. If ESCD is valid, take into consideration of the ESCD's legacy information. Onboard clock generator initialization. Disable respective clock resource to empty PCI & DIMM slots. Early PCI initialization: Enumerate PCI bus number, Assign memory & I/O resource, search for valid VGA device & VGA BIOS and put it into C000:0
27 Initialize INT 09 buffer
29 Program CPU internal MTRR (P6 & PII) for 0-640K memory address, Initialize the APIC for Pentium class CPU, Program early chipset according to CMOS setup (onboard IDE controller etc), Measure CPU speed,
2b Invoke vga BIOS
2d VGA Bios loaded, initializing display output, display VGA BIOS details, Award BIOS details, CPU type, CPU speed etc
33 Reset keyboard except Winbond 977 series Super I/O chips
3E Test 8259 interrupt mask bits for channel 1
40 Test 8259 interrupt mask bits for channel 2
43 Test 8259 functionality
47 Initialize EISA slot
49 Calculate total memory by testing the last double word of each 64K page
4E Program MTTR of M1 CPU, Initialize L2 cache for P6 class CPU & program CPU with proper cacheable range, Initialize the APIC for P6 class CPU, On MP platform, adjust the cacheable range to smaller one in case the cacheable ranges between each CPU are not identical.
50 Initialize USB
52 Test all memory (clear all extended memory to 0)
55 Display number of processors (multi-processor platform)
57 Display PnP logo, Early ISA PnP initialization, Assign CSN to every ISA PnP device
59 Initialize the combined Trend Anti-Virus code
5B (Optional Feature) Show message for entering AWDFLASH.EXE from FDD
5D Initialize Init_Onboard_Super_IO switch, Initialize Init_Onboard_AUDIO switch
60 Okay to enter Setup utility, users can not enter the CMOS setup utility before this POST stage
65 Initialize PS/2 Mouse
67 Prepare memory size information for function call: INT 15h ax=E820h
69 power on l2 cache
6B Program chipset registers according to items described in Setup & Auto-configuration table
6D assign resources to all ISA PnP devices, Auto asign ports to onboard COM ports if the corresponding item in Setup is set to "AUTO"
6F initialize floppy controller, set up floppy related fields in 40:hardware
73 (Optional feature) Enter AWDFLASH.EXE if: AWDFLASH is found in floppy drive, or, ALT+F2 is pressed
75 detect & install all IDE devices: HDD, LS120, ZIP, CDROM etc
77 detect serial ports & parallel ports
7A detect & install co-processors
7F Switch back to text mode if full screen logo is supported. If error occur, report errors & wait for keys. If no errors occur or F1 key is pressed to contine: Clear EPA or customization logo, On FOXCONN boards: OC recovery kicked in, waiting for input to enter BIOS (if your monitor stays black check if the board beeped during POST code 2b, if yes see POST code 2b)
80 Normal operation of the board after bootup
82 Call chipset power management hook, Recover the text fond used by EPA logo (not the fullscreen logo)
83 Save all data in stack back to CMOS
84 initialize ISA PnP boot devices
85 USB final initialiation, NET PC: Build SYSID structure, switch screen back to text mode, set up ACPI table at top of memory, Invoke ISA adapter ROMs, Assign IRQs to PCI Devices, Initialize APM, Clear noise of IRQs
93 read hdd boot sector information for trend anti-virus code
94 enable L2 cache, program boot up speed, chipet final initialization, power management final initialization, clear screen & display summary table, program K6 compatible write allocation, program P6 class compatible write combining
95 program daylight saving, update keyboard LED & typematic rate
96 build MP table, build & update ESCD, set CMOS century to 20h or 19h, load CMOSD time into DOS timer tick, build MSIRQ routing table
FF booting (Int 19h) If the Debug LEDs show FF but the Display stays black, check the detailled description of POST code 2b on the top
Normal Boot Sequence:
This is the sequence of POST codes you should see when booting up, note that some of them only flash on for a fraction of a second
FF
c0
A0
40
54
C3
A1
29
2b
2d
93
33
49
50
52
75
89
8b
94
95
96
FF
80
This list was copied from the BlackOPS post code thread.
Error 19 is coming from SETFSB. But info above is good to have ^^ :up:
Anandtech has a review up.
Foxconn Blood Rage - If Looks Could Kill
Go to the SetFSB site and send him an email. Be sure to follow his instructions!
http://www13.plala.or.jp/setfsb/
Edit: I'm still reading the above review but this caught my eye!
We also attempted bus speed changes with SetFSB using the correct PLL part entry. Again, regardless of a change or non-change setting, pressing the apply button results in an OS hang-up. We've reported this back to Foxconn and await confirmation that they can re-create this problem and perhaps instigate a speedy fix. Onwards to initial results….
I had a short bench session and I managed to beat my own records in Spi 32M and Vantage CPU score.
This CPU is a lot better than previous ones. It is starting to look better, but of course this is a mile behind of those diamonds we have seen. Too bad it can't do 3DM06 any better than vantage.
But still, it's starting to look like 3-way SLI time (or Quad SLI) :up:
First the 32M. With some tweaks it could be better. Memory couldn't be maxed out, cause the CPU didn't scale any hihger.
http://www.aijaa.com/img/b/00708/3304119.png
Then 1100Mz 8-7-7-20 1T (2200MHz DDR3) bandwidth result:
http://www.aijaa.com/img/b/00855/3304128.png
Too bad I couldn't find perfect combination for 32M.. those timings and speed would have been great to have.
Then Vantage CPU score at 4.865GHz:
http://www.aijaa.com/img/b/00719/3304132.png
I think, that the efficiency is ok in Vantage CPU test
Tomorrow I will try single card (4870X2) vantage and 06 etc. I hope to beat my own records on those tests :up:
The Anandtech review seems to say that the retail board is going to have a bad BIOS bug right out of the box - something about a Force Reset needed if a BIOS change is made. Can anyone confirm this that has a retail board? Thanks!
Bench, can you explain when I should be using said button on my retail Bloodrage board? Thanks!
Once I start OC'ing I will check if I have that problem or not also. :up:
SF3D: I'm paying close attention to all the results for this board and the DFI x58. Are those last screens still on water and air? Thanks.
I haven't got that Anand problem either. My first 965 ES was acting weird, but it was the CPU.
You don't need to push that button in any situation really. Bord will boot up if you just wait and try to push start button few times. If board doesn't boot at all.. power off PSU and try again.
Disable vdroop compensation. My board works really well without it. I set 1.4V in bios and I have 1.47V in load..It's better that way.
Try it Thomas and let me know how your board is working. Trust only direct voltage read from PCB.
It looks like AnandTech's issues were caused by the PSU they used.
Their reviewer ( raju @ XtremeSystems Forums ) switched to an OCZ ProXStream 1000W and the "issues" disappeared.
You can follow the conversation here
So you've "successfully" reached a point where the motherboard would not power up by simply pressing the on-board Power button ?
Pressing the Power button once usually starts the board for a sec or so, powers it down again, and starts the board again after a second or so triggering the Overclock Recovery "function" and that most of the times if not all makes the board boot fine, so you can enter the BIOS to do whatever you want.
I only had problems "starting" the board normally just once, I was pushing it too hard, and was on the edge of stability, and after saving and exiting the BIOS it tried to boot but it got stuck at A1 post code.
I just let it do whatever it wanted, without any user input, the board hang there with A1 displayed on the POST code LCD for 4 seconds, and then powered down itself.
It powered up again in 1 second, and shutdown instantly.
It powered up once again half a second later, and shutdown again.
It then powered up again and booted fine, and I got into the BIOS setup menu and altered my settings, and it worked like a charm again.
What do you mean by "predicted" Vcore Pt1t ?
You mean that you set the Vcore option to a specific setting and the board gives a totally different voltage ?
And you can't get the board to boot afterwards without removing the PSU power plug ?
Can you give us a more detailed description of what you do, what happens, and what the board does if you don't remove the PSU plug to power on again normally ?
I don't have any problems ( nearly at all, except a few BIOS related bugs that I've tracked down and reported ) that seem to be sourcing from the Vdroop compensation option.
Everything looks fine here, but I'll do some tests and measure the voltages to see if there's something wrong and I'm missing it ;)
"Trust no software" is a good MOTO when it comes to talking about voltages :p:
Hi everybody. I gotta buy a new mobo 'cause my UD5 is dead. So i've searched for this mobo but seems that isn't out. Is there any shop/man that already sells this mobo?
Sorry for my bad english :down:
I received an email confirmation from Newegg that they ship out this week.
Welp, I have to say I am experiencing strange issues on the SAS controller when oc'ing this board.
When changing the vcore, it loses my drives. Sometimes the Marvell controller comes back with CTL + ALT + DEL, but mostly the QF button sets it right.
Able to get 190 x 19 @ 920.
vCPU - 1.36 actual (+90)
vVTT - 1.20 actual (+100)
vIOH - 1.12 actual (Default)
Havent been able to get anything more stable. Still cooking..
i can't find it anywhere:(:(
i need this mobo because my homemade cpu pot has only 775 bracket and my phase also:shrug:
can anyone pvt me a shop?:confused:
