Originally Posted by
Aielman
I went with a slightly different idea. I wanted the larger amount of 5 1/4 bays because of the reservoir/pump combo I plan to use (if it ever goes on sale). So I did a CYO using a horizontal config and with all 4 sides with patterns having the 3 hole on the bottom.
I was thinking of it has having the same affect as a pedestal, but without the additional size to the case. The idea is that there will be a cooling chamber, if you will, on the bottom, with the 2 rads pulling air in front and back, and then venting right back out the adjacent sides, and then with all the left over heat up top venting through the holes on the top and back.
We'll see how it goes. I'm holding off on my build on the fair chance I may be out of work this summer, but that's giving me plenty of time to learn at the feet of the masters like yourself :)
