I thought rivatuner linked the core/shader by default.
Wanna put money on that? I will NOT EVER (not today, not a week from now, not a month from now, not a year from now, not ten years from now, or 20, or at any point in time any year of the future) will I fall into that fad. It is stupidly expensive, stupidly expensive to watercool, horribly innefficient, eats up a rediculous amount of wattage, and I won't be buying into the bugs they come pre-equipped with. On top of that, they usually downclock the GPU's which is the opposite of what I do with my systems. I OC...I don't do UC's.
One powerful GPU per card is all I need. It's all I will ever need, because if there is ever a need for more than that, then it's time to buy a new video card. There will never be a use for dual GPU's on one card. That's what SLI is for. One heat producer per card is enough.
It is likely that it will come a time when this is the only options for the topend cards (once more refined) from both NV and AMD. So far NV is the only one doing underclocking on there multi GPU but if they ever design a chip for that purpose im sure there would be no need for UCing.
Multi-gpu is going to become the norm for the highend soon. And it is going to follow a similar progression as CPUs:
separate sockets (ie, separate chips and/or boards) and poor software compatibility (ever try to install win98 on a 4 socket PPro server? Lol) ---> better multisocket solutions and good software support (winNT,2000,XP,linux,etc) ---> mutiple dies on the same chip package ---> native multicore
The thing holding multi-GPUs back is not having the ability to share the same memory pool. But you can see that issue is being tackled by intel with larabee and you can bet that the other two are chasing the same goal.
Multiple dies on the same package is an entirely different matter, and one I support and is the reason I will never support this "double cheeseburger" arrangement. I wouldn't mind if it has 80-100 dies, but it better be under one IHS to put one cooler or block on top of. I wouldn't care if the package was 4 inches square.
With dual GPU's side by side all you get is double the heat, double the electric bill, but nowhere near double the performance. On top of that you get the microstutters. You double the price of your cooling, it puts more stress on the boards. It's a bad idea that should've been ditched after the first one of those blunders was unloaded on the market.
Cool. Hope Tek9 fits.
I met with few guys here last week, working with industry as well as media... all of them were saying new GX2 is about to hit the scene soon. NVIDIA has software development center in city of Pune [not far from Mumbai]. Performance of GX2 was not talked about a lot. So I am not surprised by news. ;)
from the article
The point 2 is referring to point 1, not the whole article. As in "Smoking Sepuku", not everything Charlie said (not that he is always 100% correct anways). I bolded, underlined, and made the 2 huge so you can see what it was referring to.Quote:
(1) It was code named "Smoking Sepuku", but Nvidia didn't want to publicly suggest that this strategy was vaguely related to anything honorable, so it was renamed. We saw the memo, it was poignant. (2)
(2) We are, of course, making this all up.
loved that, hahaQuote:
Whoopty-fricking-ding-dong.
if inq is right, and this is a big if, then nvidia will slowly die out or will have to conform to amd's strategy
I told it before month, launch was only postponed from 22.10. to november ... :rofl:
Delayed again? What`s wrong with NVIDIA? Doesn`t have competitive GPUs (price/performance) to AMD and launch date of it`s refresh parts is delayed and delayed again. It seems that AMD is going to be king of hill with another couple of months (it has the fastest card and the best performance/price ratio single GPUs).
@OBR you have told NVIDIA is going to release MANY more than only GT200B but according to TheInquirer this is ONLY GT200B; GTX290 with full GT200B specs and GTX270 with disabled some parts like GTX260 to GTX280 (i`m talking only about hardware). Moreover NVIDIA doesn`t need much faster GPU at now but cheaper so it doesn`t have to release HD4870X2 killer but need to release HD4870/4850 killers with Price/performance ratio. ;)
i freaking hope multi gpu, 1 card solutions dont become the norm, some of us act like SLI/CF dont exist, including me. Single card always until they fix the problems with SLI/CF. If they wanna lose my business to Intel. (granted they keep single gpu cards in the market) then thats what they would do, if they made multi gpu the market norm.
I think that multiple separate gpus (whether they are on separate cards or the same one) will be around for a while - even after you get multiple dies under the same IHS. It's for the same reason that multi cpu still exist even though we have quad cores (well not the only reason). There is always someone that wants or needs more and an easy way to get that is to put together multiple of whatever is the best currently available.
This is the real crux from my perspective. Software support needs to be better. Games and applications access the GPU through APIs. The GPU manufacturers need to make their drivers (or hardware) in a way that handles spreading the load across multiple gpus transparent to the API. Having to make a special profile for each game isn't going to work in the long run - it just puts more strain on the driver development team. Instead the GPUs (or drivers) need to have logic that will allow them to share memory and share the workload on a single frame: thus simultaneously ridding us of AFR and the doubled up memory.Quote:
I believe the quote you have in there, is wrong. Not wrong maybe a few years ago, but wrong right now. Dual GPU solutions aren't perfect (like say the 4870 X2) but they are still pretty damn good if you know what you are getting.
I know I have gotten double performance in various games, almost perfect 100% over 1 GPU. And the whole Microstutter thing is blown way out of proportion, most people think any stutter that occurs = microstutter, when in fact it is likely just a driver bug.
On some other forums we have a X2 thread and it is quite obvious the X2 is only as successful as the driver you use. Some people report stuttering, in say, Crysis. All you have to do is point them to a better driver and it goes away. We also recommend Vista 64, as the CF drivers are much better on there compared to anything on XP (32 or 64).
Either way when you get a dual GPU setup (whether CF or an X2) you have to be aware that brand new games are not going to be profiled and performance will be bad. There may be a day when this doesn't occur, but it is what happens right now. You just have to be aware of it, and if you don't like it there are plenty of single GPU solutions you can use (such as the GTX 280). (or do what most of us do and diable Catalyst AI and just use 1 GPU and don't take performance hit)
And regardless of what you or others think, multi-GPUs are going to be the 'way of the future' at least, at AMD. But you are right that with that software becomes the most important part. Drivers will sink or swim these, but they are here to stay. I also think the R800 is actually uses MCM and might not have to use AFR/Pooled memory.
I still find it quite hilarious, but bad for Nvidia that after, how many years?, ATI brings out 2 cards, ok now 3 with the 4870X2 that can beat Nvidia. The aforementioned 2 (4850/4870) are not ahead of nvidia by only a smidgen, they win only on price, so everyone starts calling nvidia dead, they are doomed, omg nvidia lost!!
the fact is boys and girls, ATI has not produced a competetive card since the 9600/9700/9800 series. the X800/X850 series was nice too but all along nvidia was raking in the profits and hearts and minds of PC enthusiasts.
Nvidia has lost the race 1 time in nearly 15 years, and people are dooming nvidia, and frankly all this bashing by the community and websites is truly hurting nvidia.
Now granted nvidia has hurt themselves, no one will deny that, with their fixed pricing, yada yada yada, and their mobile chipset solder issue, but to label them losers in the video card race is just total bullsh|t.
I like any card that has the power to do what i want it to do, and frnakly i like the GTX260/280 and the 4850/4870, so in my mind everyone wins.
but this continued smashing, raking over the coals, and literal market killing talk about nvidia has got to stop.
ATI, 1 time in the last, oh 6 years produces a card that has FINALLY overtaken Nvidia (4870X2), and all the sudden ATI is king.
this is the hilarious, and you people flip flopping, and bashing and raising ATI from the grave are hilarious.
ATI is in FAR FAR worse shape than nvidia E V E R will be financially.
^^^ i agree
What are you talking about? ATI has been competitive with NV (frequently beating NV) with the sole exception of the R600 generation.
For example, R580 completely destroyed its competition, especially now (sometimes even 100% faster than G70). R520 was slightly delayed though, although ATI has now improved on its execution.
This is a return of ATI, new and improved in the following areas:
1. Execution: no more (or fewer) delays!
2. Cost effectiveness: smaller die and cheaper PCB means cheaper to manufacture, which means we can buy a 4850 for a mere $150.
That's because NV's engineering R&D budget is equal to ATI's revenues (or something along those lines). What do you expect when one company is 10x larger than the other? :rolleyes:Quote:
Originally Posted by Lestat
You can't really make that comparison, though.
Ive lost hope on NV with this gen. I just hope that they will be able to work some magic around R800 time.
