Do you have : Sketch up Coolermaster Case (Original) or Detail
'Because now i using my case and i need adjust database but i didnt have any detail then send file to me please
Thank you . . . AGAIN . . .
yeap it fits with no problem
unless you're planning to place it in front of a card like 5970
in that case i suppose its gonna get tough pluging in those sata cables
so close to the card
apart from that i don't think it has any other problems,
(some might not like the perforated aluminum faceplate,
but thats totally up to you to decide.)
i used it to swap non raid storage disks that where plugged in the secondary sata controller of my board
so its kinda like using esata
no need for a raid card.
we also used to build some limited production BTO systems
based on 833 stackers and utilizing a hot swap cage like the kingwin model
lowfat suggests, also with no problems at all
except maybe for the kinda noisy stock 80mm fan
that came with the cage.
Waiting for a dream come true.^^
Y_Y waiting for Detail 830 Y_Y
wow! I'll wait for that dude! 800d is a HUGE and NICE case!..
here's mine:
http://i6.photobucket.com/albums/y21...g/_MG_1740.jpg
http://i6.photobucket.com/albums/y21...g/_MG_1741.jpg
i'll also update new photos and new modifications here..! :D
Nice! ^^
a little update to my stacker :)
[IMG]http://img808.imageshack.us/img808/2...0101616.th.jpg[/IMG]
nice set up dude!
do anyone have a link to 83x stacker with radiator at front bay?
First let me say this picture is not mine. This shot belongs to " jbl2226h " when I saw this picture I was sold on getting a CM Stacker 831 SE
It Just Blew Me Away..let us know what you think ? :clap:
I call this picture..A Work in Progress .
http://img834.imageshack.us/img834/5549/dsc0478ut.jpg
looks intersting
and where is cd-rom?
As far as I know and I've looked at this build process about 100 times..he did a good paint job on the cd/dvd case..(black)..but never installed the drive ?
I would leave it like it is,and use a usb drive only if I need to. my 2 cents :cool:
well it would be too simple if i could throw away a cd, i could put triple rad in front then)
I know water would make this build "Overclockable",I think he just wanted to personalize it and make it simple but elegant..I think it's great like it is.
how these fans in front are mounted? i know one way is to use fans holders from back side panel, is it this?
No :) They are Stacker fan brackets, they are sold separately :)
http://www.ipcrepublic.com/images/pr...0fbn1_main.jpg
Yes, these are brackets that came on side fan panels, i have 4 of them.
The only thing I don't like much is this cut on right side on the photo, being installed on front bay this looked not so good.
You are right,never had that side fan panel :)
