So to custom watercool your Rampage Extreme, it is basically the same as the Maximus/Rampage Formula series, but you may want to also consider cooling the power delivery system of the NB, as it tends to get pretty hot with the 3 phase/15 mosfet design (8 front, 7 back).
What's the difference from watercooling with the Fusion block compared to what I have now I hear you ask? Before this makeover I cannot put in more then 1.65V into the NB without the RE refusing to boot, and at that voltage the NB, when under load, goes up to 60C+. Now however, at 1.7V the NB temp is kept nice n cool at under 42C under load, and plenty of room to go higher without cooking the board. That means longer component life and higher stability!!:up:
http://gallery.me.com/jeffrey_lee/10...12176099890001
