gotcha :) yeah ill see what i can do :)
and i thought you were serious :p:
ooooo them look purdy, hope to have one on my SS somtime :D. but question, why 3 holes? am i missing something here?
1 hole is for the cap tube, the other 2 holes are for the suction :)
gah! camcorder isn't working......
http://i198.photobucket.com/albums/a...h_DSCN2530.jpg
http://i198.photobucket.com/albums/a...h_DSCN2531.jpg
brazed and cleaned. the itty bitty kitty commitee took over sorry about that
Wow what an ugly kitten. jk
But seriously, im not gonna lie, that evap looks SUPER NICE.
Super clean man. :up:
Dont you have a webcam or something lying around that you can record with?
no sorry i dont' :(... will a picture of every step suffice for now?
love the pic with the kitty!!!! i also like the taller/rounder top.. should have my unit up within next 2 weeks... or if i can find a good compressor(in-town) before then... just dieing to get one up..... :yepp::p::cool::rolleyes::D
thanks again for the evap..
JB420
hey!
the rounder top is a cap instead of a sleeve... a bit more costly but a bit easier to braze. thanks for the compliments :) let me know how the insulation works out for you... :)
steven- :p: i already started it with only 2 pics so far lol sorry. ill take more :)
me brazing up a evap-
http://i198.photobucket.com/albums/aa15/teyber/b.jpg
http://i198.photobucket.com/albums/aa15/teyber/a.jpg
(p.s. im not hugely fat in first pic i just am standing in a funny position... lol)
Pics of cleaned evap soon...
Teyber your torch is not set correct and its too far from the work.
BTW is that a welding helmet your using to braze with? I hope its the variable shade model.
Teyber do you know what a long haired HVAC tech becomes eventually........A short haired burn victim.
Also milling machines and lathes are very good at ("scalp-em's) rip the scalp right of your head, you can die from bleeding since there are so many blood vessels in your scalp.
He doesn't have long hair? :rolleyes:
http://www.everaftercostumes.com/snood_carolyn2.jpg
I got one you can borrow teyber
:rofl: :ROTF: I think that's why they have the safety label 'Caution: Don't Stick Your Head Into The Spinning Shaft' ;)
I see you're still not using enough O2. :shakes:
Teyber your gas supplier will have demo torches,ask them to show you how to set the flame properly. should be 2 to 5 psi acet depending on tip size around no more than 8 to 12 psi o2 for light brazing.
Holding one of his Signed Limited Edition Evaps in my hand right now.
These are very nicely done, good quality with lots of attention to detail.
Great Job Teyber :up:
oh yeah, get a hair cut LOL, sorry could not resist :rofl:
hey!
hair is being cut today... whenever i use my mill i actually put my hair up (no joke) with what looks like a big rubber band, but made for hair. The welding mask is temporary... i use oxy/acet goggles but they are cheap, the band got so stretched out that i was brazing and they just fell off my head... closed my eye's and jacked up the o2 till the flame blew out, using this till i replace it. the welding mask has a ansi # 8 shield.
keep in mind the first pic is without oxygen... is that what you guys are referencing to? oxy is ~ 12 acet is ~ 6psig... When i braze the end of the flame is not blue... if i have more oxy it blows out. tips or is this normal?
cheers buckeye :)
No we are referring to the second pic. If you add more O2 and it blows out then your acetylene amount is wrong.
Turn the acetylene up until it stops producing soot. Then add the o2.
Oh and I don't use goggles with flame, only arc.
my dad is blind from the top left side of his vision. he has had a total of ~ 4-5 different eye surguries for 4-5 different things (cataracts, detached retina, et cetera). i love sight and hope i die far before i loose my sight. If wearing a pair of goggles or putting something on my head will help keep this from being true its far worth it to me...
walt you say 2-5psig... ill try using less...
cheers:up:
sweet looking stuff you got going on teyber :up:
