Originally Posted by
soapman72
Thanks for recommending those settings. My own are very nearly the same as you suggested, however, with a performance level of 6 selected, I need 1.45v on the NB to keep the system 100% stable during 3D gaming. Prime was stable at 1.41-1.43v, but gaming seems to need a touch more at PL6. I also run PLL at 1.50v and FSBT at 1.10. I don't know if these 2 settings are responsible for my headaches with the tighter timings, but they certainly don't keep me from finding stability at 7-7-7-20.
I have the EB Platinum 4gb OCZ memory, and have had terrible luck with it. I cannot run it at 7-6-6-24 as it is rated. I am forced to run 7-7-7-20. I can't even get the kit to run 7-7-6-24 without Memtest errors. I have RMA'd two kits already.
I am nearly ready to give up on this memory as it will not even overclock by even 5mhz at 7-7-7-20 timings. The folks at OCZ keep suggesting that I play with clock skews to get the memory stable, but I have not seen any improvement when I sried MANY MANY different combinations of skew. I tried both delay, and advancing the skew. No difference.
Thanks again, and any suggestions would be appreciated.
Sean
