I get 16,365 w/ my 8800GTS-512 w/o v-mod & quad @ 3.8GHz.
I get 17,705 w/ my 8800GTS-512 w/ v-mod (864/2268/1150) & quad @ 3.8GHz.
Your scores look like you only have 1 GPU working.
It will be interesting to see how this scales against Hipro's numbers with dual HD3870X2 cards....which were on air during his run:
LINK
Also interesting how somehow the ATI cards suffer in the CPU Score department even though Hipro's CPU was clocked higher that the one we see in this thread.
IMO, it will be REALLY close between the HD3870X2 and the 9800GX2 once we see more HD3870X2 LN2 results.
Aw man, Vince. You're making me want to switch back to nvidia again. This combination of the 790i and the GX2 sure is tempting:yepp:
Does anyone know if there's going to be a 790i with DDR2 support? I really don't want Nvidia to leave 95% of us out in the cold for not having DDR3 :(
You an find DDR3 now for around $250-$350.00 2GB. Do not buy the DDR3 2000MHz stick that will cost $600.00 Look at the Crucial sticks I got on ebay for $200.00 that can do all of this, compared to the 1800MHz sticks.. And I can go up to 2000MHz as well... :)
http://images.tomshardware.com/2008/...ng_results.gif
(Awesome numbers Vince! Grats!)
Yikes... I don't know if posting some nice benchmark numbers is worth running VISTA.
What do y'all think? I kinda want to try the GX2 out but somehow it seems like this will only be a good benching setup due to the 512 video ram situation. Any thoughts on this?
Right now I'm running 8800Ultras in SLI on a 30" monitor at 2560x1600. Do you think it'd be worth it running GX2's in SLI for gaming at that resolution?
I'm usually an impulse buyer with this kinda new stuff but this one seems so borderline its making me stop and think...
I ran a couple passes of 06 over lunch, got 19K with stock clocks on GX2, and QX9650 at 3.66. This was on a 780i however. Ran overclocked via Rivatuner 750/1140/1900 and got almost identical score, I obviously have some digging to do to find the catch. Nvidia control panel has no "set SLI" like with older cards, only multi-gpu or multi-monitor.
Is it possible to flash XFX 790i mobo with eVGA 790i bios ?
'fubarswe' reached 500MHz FSB with QX9650 on this board today. As I can remember it is VERY rare to see such high FSB with QX9650.
http://loppmarknader.se/blossas_albu...b500937zh4.jpg
Very, very nice vince.
Quad-sli still under NDA? When can we expect result? the 25th?
Thats another 5 day's of F5 terror :D
Tweaktown has'em I suspect Vince got them as well....
Think that they may still need some work, but hopefully Green will have the WR back soon :)
Take Luck Vince, along with some of those OC'ing Vitamins ;)
Are we waiting for the nda to pass ? Those LN pots are beautiful , enough to convert a water cooling guy .
:up:
awwwww man!
AWSOME :eek:
so kingpin, when are we gonna see those quad sli results:D :p: ;)
