yeah, amazing job
PC70 (WIP)
http://img827.imageshack.us/img827/9231/img6164.jpg
http://img833.imageshack.us/img833/251/img6163.jpg
http://img836.imageshack.us/img836/158/img6143u.jpg
http://img842.imageshack.us/img842/3433/img6139.jpg[/img]
http://img828.imageshack.us/img828/2742/img6160.jpg
http://img832.imageshack.us/img832/4263/img6159.jpg
http://img832.imageshack.us/img832/1329/img6156j.jpg
http://img841.imageshack.us/img841/1583/img6153.jpg
http://img832.imageshack.us/img832/7117/img6144.jpg
http://img843.imageshack.us/img843/8493/img6204.jpg
http://img837.imageshack.us/img837/7786/img6202.jpg
http://img827.imageshack.us/img827/2486/img6189.jpg
Ooooh very nice pictures!
Worklog is here.
http://i2.photobucket.com/albums/y26.../Clearance.jpg
http://i2.photobucket.com/albums/y26...er/Overall.jpg
http://i2.photobucket.com/albums/y26...ubing_Done.jpg
http://i2.photobucket.com/albums/y26...ter/Mess_2.jpg
I know it's a mess right now. It's hard to watercool a mATX case and have it look perfect. I'm going to be modding my PSU next to have shorter cables and get rid of the ones I don't need.
CPU:Intel i7 930 OC @ 4.2Ghz
MB: ASUS P6X58D Premium
GPU: EVGA GTX480 SuperClocked+
OC @900/1125/1800
RAM: G.SKILL 6GB (3 x 2GB) DDR3 1600
SSD: OCZ Vertex Turbo
H2O cooling parts:
-Watercool HEATKILLERŽ CPU Rev3.0 1366 CPU Water Block
-Black IceŽ GTX Gen Two Xtreme 560 Highest Performance Radiator
-Feser X-Changer 360mm
-DangerDen GTX480 Nickel Top and Base
-Bitspower Asus P6T/P6X58D NB/SB Water Block
-2X Swiftech MCP355 12 VDC Pump
-XSPC dual Clear Acrylic Pump Top
-EK 150mm Reservoirs with silver strip
-3 gentle typhoon 1150rmp
-4 Yate Loon 140mm Medium Speed
http://lh5.ggpht.com/_Q78uqzOpXvY/TE...0/IMG_8762.JPG
http://lh3.ggpht.com/_Q78uqzOpXvY/TE...0/IMG_8738.JPG
http://lh6.ggpht.com/_Q78uqzOpXvY/TE...0/IMG_8764.JPG
http://lh3.ggpht.com/_Q78uqzOpXvY/TE...0/IMG_8767.JPG
http://lh3.ggpht.com/_Q78uqzOpXvY/TE...0/IMG_8803.JPG
http://lh5.ggpht.com/_Q78uqzOpXvY/TE...0/IMG_8781.JPG
http://lh4.ggpht.com/_Q78uqzOpXvY/TE...0/IMG_8774.JPG
nice pics mate!
http://img828.imageshack.us/img828/9461/img7205.jpg
http://img831.imageshack.us/img831/911/img7180.jpg
http://img819.imageshack.us/img819/4189/img7176.jpg
http://img833.imageshack.us/img833/4985/img7175.jpg
http://img146.imageshack.us/img146/3569/img7170u.jpg
http://img62.imageshack.us/img62/9456/img7200d.jpg
http://img704.imageshack.us/img704/8116/img7197a.jpg
http://img408.imageshack.us/img408/1492/img7192f.jpg
http://img185.imageshack.us/img185/2930/img7186.jpg
http://img517.imageshack.us/img517/7451/img7201s.jpg
http://img9.imageshack.us/img9/2729/img7203b.jpg
Update New Reservoirs Bitspower Water Tank Z-Multi 150 :p:
http://image.ohozaa.com/iv/lqzl5.jpg http://image.ohozaa.com/i1/9xv76.jpg
ram blocks connected serial? I strongly advise to connect them in parallel. Ram dissipates only very little heat, almost always even simple air cooling is more then enough, so most cases where ram LC is used it's for bling. But connecting such resistive water blocks as for ram ones (very small crosssection, tight flow bends) in series simply is killing overall flow in loop with no practical gains and hurting cooling of other components in loop which actually make up biggest share of performance and which might profit from extra flow for better cooling/better overclocks.
My Lian-li Xbox 360 build.
This was my first Lian-li.
http://i28.tinypic.com/2r3h1l3.jpg
http://i31.tinypic.com/244aclz.jpg
http://i26.tinypic.com/hs3prd.jpg
http://i31.tinypic.com/2gu9yfn.jpg
http://i40.tinypic.com/294gnfd.jpg
This pic was to test the lights, later I turned the pump with the resevior around.
http://i40.tinypic.com/23rr0k4.jpg
Kerensky, Lu(ky, awesome builds :D. (btw, nice to see you found your way here too Kerensky ;) ).
Lu(ky what a beautiful job!
Thanks I really like how it came out for my friend. Had a hard time getting the one side of case closed do to the wires.
http://i274.photobucket.com/albums/j...IMG_3514-1.jpg
http://i274.photobucket.com/albums/j...IMG_3500-1.jpg
http://i274.photobucket.com/albums/j...IMG_3508-1.jpg
http://i274.photobucket.com/albums/j...IMG_3507-1.jpg
Did you paint the RAM fan?
I got everything powder coated about year ago..
The case use to look like this air cooled.. Here is a link to a SLIDESHOW
http://i274.photobucket.com/albums/j...7/IMG_0955.jpg
My first go at watercooling not compeltely finished yet, full work log http://www.xtremesystems.org/forums/...d.php?t=256690
http://a.imageshack.us/img101/5715/wc7x.jpg
http://a.imageshack.us/img440/5602/exterior1.jpg
http://a.imageshack.us/img835/477/inside2u.jpg
here,s a pic not sure if it,s any good... please give me feedback if liked will post more pics
http://i115.photobucket.com/albums/n...1/DSC02952.jpg
system specs
#Motherboard : MSI X58 PRO-E
#CPU : Intel Core I7 920 2.66mhz @ 4GHZ
#CPU Cooling : watercooling
#RAM : 6Gb kingston Hyper X ddr3 1600mhz
#RAM Cooling : standard heatsinks
#Graphics Card : ATI MSI 5870 IN CROSSFIRE
#Graphics Card Cooling : Stock
#Power Supply : INWIN COMMANDER 1500W
#Chassis : lian li a71
#Fan's : 10x 12cm fans, intel fan (Northbridge)
#Hard Drives :
1X300Gb Velociraptor 10000RPM
8 X 2tb western digital green drives
1 X 1.5TB SEAGATE DRIVE
#Optical Drives : LG usb
External Hardware :
#Keyboard : microsoft sidewinder X6
#Mouse : microsoft x8
#monitor 1 : sony Bravia 40" 1080P LCD http://www.sony.co.za/product/klv-40s400a
#monitor 2 : samsung P2450 24" full hd lcd
Looks like a nice rig apart from the totally crap In Win PSU. It may do 500w cleanly. I wouldnt trust it past that.
http://farm5.static.flickr.com/4109/...545bc0b6_z.jpg
http://i817.photobucket.com/albums/z...l/Img_7307.jpg
http://i817.photobucket.com/albums/z...l/Img_7305.jpg
http://i817.photobucket.com/albums/z...l/Img_7298.jpg
http://i817.photobucket.com/albums/z...l/Img_7293.jpg
http://i817.photobucket.com/albums/z...l/Img_7275.jpg
http://img819.imageshack.us/img819/9913/img7326.jpg
http://img186.imageshack.us/img186/6669/img7327o.jpg
http://img153.imageshack.us/img153/3358/img7400uj.jpg
http://img844.imageshack.us/img844/4580/img7395.jpg
http://img155.imageshack.us/img155/428/img7390g.jpg
http://img202.imageshack.us/img202/4200/img7396b.jpg
