I did some 8 drive tests and they were better.
I'll post results soon.
@Gruber: I will try how the controller works in 16x slot. But I was told on 2cpu thread that there shouldn't be any problems.
@jcool: I went for the lowest possible power option. the XOR you mentioned is very fast. I would very much like you to make a RAID5 config of some sort and do some back to back comparison with 9650 you have.
Speed will ot be a limiting factor in media fileserver. The only time it will be written on it will be when I offload some PC on it, and that will be over network so I won't be seeing >60MiBs anyway.
Read speeds wit 8 drives are more than good.
The only thing that coulld be benefitial IMO would be faster raid level migration, rebuild times and verifications. And I really wich someone could make those tests as those numbers are nowhere to be found.
And please do this on both controllers: make a large folder with pics and such files and copy it on the array itself. THAT is the ultimate test. R/W at the same time! Do the same with a large 4GB single file (best would be video).
If you can't do Raid5 then at least Raid0, but that wont tell us much how much difference is between each XOR when calculating parity. :/
