no problems here, no pmxgl32.dll and i had scanned the zip with nod32 before i opened it
for those who may be interested:
BIOS for 3850 256MB v71 unlocked
3dvoltage @ 1.333v
3dcore @ 780mhz
3dmem @ 1030mhz
2dvoltage @ .974
2dcore @ 300
2dmem @ 830
bios IS checksum corrected.
I was able to flash with ATIwinflash w/ no problems =)
if you guys wish me to make diff clockspeeds bios's please post what you would like, I will try to do so =)
OK, to end this soap opera, we need the administration to test the file pointed out by Truckchase please, if they find that it installs a Trojan, then by all means, ban me, if not, then i would demand a warning to Truckchase, and for your information, i excuted the file dizzillion times, and it never installed ANY DLLs or viruses, or weird files.
And i think this is the best solution, and till then, please keep this thread on topic, cause this is getting rediculous!
I paid ;) . I read the thread dozens of times, flashed lot's of bioses from this thread, including mine modded. But now I had this "doubt" and I wanted to post to ask you if it was a normal value of vgpu with RT (never checked voltages with RT before). I know you can't pass 1.29 via bios. Only asking and sharing with you this info, that's all.
Hapy holidays, and thanks you all for your work :up:
Thank you very much for that one! :up: Cards now run at 776/1026.
However, when usin CCC Advanced and looking at the Overdrive tab I get the message:
"ATI Overdrive capabilities have not been properly initialized yet. Please try again later"
Any clues of how to solve that? I have cleaned all drivers and reistalled it again, did not solve anything.
Thanks in advance!
/ Anders
EDIT: The service 'ATI Smart' is set to automatic, however, it only starts för a second then it stops again.
well it would seem that whenever the frequencies are programmed in the BIOS...as all of us have experienced here OVERDRIVE gets weird and stops working at least halfway. With the bios I edited the max on core was 730 in overdrive...since I programmed the bios to go above 730...I think OVERDRIVE is just totally freaking out. So, I dont think its nothing major. As Im trying to just hard lock in the frequencies without having to do any clock changes once I find whats stable =)
Flashed to your bios ealier and can confirm the same overdrive problem , i have a bios that doesnt break overdrive thats clocked 760/1000 with 1.33 3d , think its the only one i have tried that overdrive still works with , its the one i linked to on the first page , its not 71 bios with fixed max core thing , maybe thats why overdrive still works with it :shrug:
Anyway im using your bios as its close to my max core 785 ish and 1035 , so its leaves a bit of headroom
cheers :)
Good thinking. :D I have the same opinion as you.
Before testing this one I had a bios with something like 766/1000 and max for me in Overdrive was 770/xxxx. In that case Overdrive worked but as I was already (almost) maxed out already it was just to leave the settings for clocks alone and keep benching. ;)
I will keep your bios for awhile and see how it works for me.
chrisf: Is 785mhz max for you becasue of the voltage or temps?
GenTarkin you made a brilliant work with this bios for hd3850 256MB.
can u modify for me 3d mem @1ghz and give a link ? . anything else is just perfect.
Thx
Downloading Avira AntiVir to give it a run...
os008, wanna be a bit more calm about this? Nobody's pointing a gun at you or threatening a ban.
Just checked the directly linked HexCmp on http://virusscan.jotti.org/ (which uses a bunch of different scanners) and it turned up "clean" . That ofcause doesn't mean it can't be infected... maybe the scanners used there just don't know the virus yet (which on the other hand I find hard to believe if it's a "well known" massmailer).
[edit] Scan on http://www.virustotal.com brought different results :Code:Antivirus Version Last Update Result
Microsoft 1.3109 2007.12.29 VirTool:Win32/Obfuscator!Mal
Panda 9.0.0.4 2007.12.29 Suspicious file
hi everyone =-) I will work on modded bios's like in a little while, my GF is in town and Im spending nearly all my time with her =) shes a darlin hehe....
:) Great work and fast. ;)
I think once my gf heads home...I will be trying out the newly discovered pencil mod and then upping these bios's to 1.4v or so...
this work with HD3870 Bios??? (sory Offtopic)
regards
Would someone mod my original MSI HD 3850 256Mb BIOS to 760|1000? The card comes clocked @ 690 and is capable of the first mentioned OC.
MSI HD 3850 OC 256Mb BIOS
http://members.cox.net/malficar2/MSIhd3850
Great job .
THX man . you are boss
