what would the errata bug do... what is the real issue it could cause?
it would freeze ur computer, i was told it would only happen if you loaded up the entire cpu.
Here, the first page of this is mainly about the bug.
http://www.rwlabs.com/article.php?id=10
Here is my OCing break down.
The Asus board I am using doesn't like to go over 215 HTT.
The chip that is pictured on the left (see the stepping) doesn't like to go over 2550. I limited myself to 1.35V.
I will read your article thoroughly later. From what I've gathered, 2.8GHz with stock cooler is doable at 1.35v. Do you think it can do 3.0GHz under water/high-end air?
Am aiming for 3ghz/3.2 with my Asus M3a32-mvp 790fx and 9600 on water! Currently 2.7 stable had it at 3.3 but was very unstable on stock volts ill get there!
keep up the good work Bro20000
Hardocp has an unlocked 9600 on their site. Made it to 3ghz stable. Good showing...
Mike you gonna move on a Phenom down the road?
Supposedly Phenoms don't like high fsb, but how does it react to OC if you lower the fsb to 180-170 and rise the multiplier to 18-20.....
Might sound stupid but has anyone tried it?
P.S. I have no experience in overclocking a AM2 system, so I have no idea how it affects memoryspeeds. The last AMD-system I overclocked was a socket 939.
It seems that everybody is holding out for the B3.
Just order a 9600BE, but with the hollidays comming, i dont think I will have it untill late next week... Will keep you posted!
An article about TLB erratum someone found and posted a different forum thread, I found it quite enlightening.
So wheres this thing at man?????:rolleyes:
I'm really looking forward to the BE being released in AU but I cant stop thinging about how much more power these Penoms draw compared to intel quads, its ~ 40% more across the board and close to 90% more compared to the upcoming .45nm parts from intel
Why so high ?????:down:
B3 is the safer bet:)
Same here am waiting for b3 till i upgrade again!
Unlocked Multi is Marketing Scam to stay afloat and be BETA Tester at Best!
B2= Rc2
You can't change the HT ref. value to below 200MHz. ;)
The unlocked editions don't like HT ref. high, typically lower than the multi locked editions. I've so far heard of 230MHz being the best limit and 201MHz being the worst.
I have been looking all over the place everyday and haven't found one
e-tailor with these in stock (or more importantly that I've heard of at all) Anyone actually seen these in stock and/or ordered one yet?
