Originally posted by Gary Lloyd
I haven't been able to find a picture of an accumulator online, but I will try to describe it for you:
The refrigerant coming back from the evap dumps into a large shell. Inside the shell is a U shaped tube. One end of the tube is open. The tube goes down to the bottom of the shell, then up to the top where the non-open end attaches to the suction line back to the compressor. In other words, the compressor is pulling vapor from the inside top of the shell through the U-shaped tube. At the bottom of the U is a small hole. When the compressor is running, liquid feeds very slowly into the vapor stream through that hole.
I hope that made sense.
although i did know that and they are easy to build but.....the problem with running the tube like that on my manifold is...
