I was playing around w/ nibitor today, and was able to add entries, but I'm still afraid to flash it. I was having problems w/ nibitor acting funny until I found out I needed to change the VID bitmask to accommodate the additional entries. Now Nibitor seems to be working fine, but I'm still not sure if I can or need to change the amount of active entries to a higher value. Or should I change one of the 4 already active entries to a higher VID? Or just make Exact 1.2 (for now) and be done w/ it?
http://img108.imageshack.us/img108/2...toredithc2.jpg
http://img410.imageshack.us/img410/2...itorvidhq2.jpg
http://img267.imageshack.us/img267/5...orexactjm1.jpg
Comments? Suggestions? Brave souls?
Edit: I changed the number of active VIDs back to 4 b/c 8 was showing up as 0 when I reloaded the saved BIOS. But I can still select Entry 4 to be "VID 5 1.2v". Then I can set Exact to 1.2v. This seems like it might work, but I'm too chicken to try it first.
http://img256.imageshack.us/img256/9...getablewk7.jpg
http://img513.imageshack.us/img513/5...orexactcx5.jpg
Edit2: It seems that since I can't change the number of active entries above 4 (and have it stick) that it makes no sense to have additional entries in the table. Once I changed entry 4 to VID05 it overwrote VID03 to VID05. So any additional entries are ignored from the viewpoint of Nibitor. Now what I've done is to just overwrite the first 4 entries to have higher VIDs and higher corresponding labels (it starts w/ VID02 now instead of VID00). It shows up correctly in Nibitor, but I'm still scared to give it a try.
http://img209.imageshack.us/img209/1779/nibitorgf3.jpg
