Will you be running an AMD system?
Couldn't resist another run while waiting for new stuff.
http://service.futuremark.com/compare?3dm06=4017837
http://img249.imageshack.us/img249/7366/29934943lj0.png
3DMark Score 14177 3DMarks
SM 2.0 Score 6496 Marks
SM 3.0 Score 7232 Marks
CPU Score 2857 Marks
8800 GTS 640Mb SLI 646/1976
Weird that it shows my 6400+ X2 as a Sempron :shrug:
Better crank those 3870's Lightman! :)
WOW!! :shocked:
Amazing job on those GTSes!! :clap: :clap:
Finally I'm beaten to death!!!
Now it's time for resurrection :D
Let's see where my Hiper is know.... well still on CityLink Van :p:
Besides I'm back Wednesday night, so probably serious session will be Thursday ...
I'm just afraid my low clocked Phenom wont let me pass 14K....
Still I can use my secret weapon and voltmod HD3870 ;)
PS. How you cooled your CPU?? Phase? :)
I decided to try windows 2008 and wanted to see if it was any faster than Vista. Windows 2008 does allow you to decide if you want certain features loaded, but even with all of those features loaded it was quicker than Vista. The cpu score was quite low, but the other scores were almost identical to what I get in XP.
@Flasker: Thanks for quick answer!
@PhilDoc: Interesting findings..... was it x64 or x32 version?
It was the 32bit version. For both Vista and 2008. Loaded Crysis on it also and its actually runs better then Vista. Should have tried it with everything turned off. With all the features loaded, it looks just like Vista. I also tried 2003 64bit, but it was slower than XP 32bit, buy about 200 points. That kind of supprised me. Must be the drivers, maybe something you should check out when going for the record.
I will definitely be running Win XP x32 for record breaking :up: ! This is caused by instability of my Phenom on x64 OS above 2.5GHz. I should be able to hit 2620-2640 for x32 runs though :D ...
My record breaking attempt is delayed till tomorrow due to new PSU delivery problems :(
Sorry to hear about the PSU problems, but good luck. Expecting great things from you.
Wrong thread. Sorry.
I know that Psycho_Eddie is getting older with every day, so I decided to publish my 3DMark06 scores with HD3870 and Phenom powered by my new HIPER 4M880 PSU!!
http://img80.imageshack.us/img80/2156/1000622hd8.th.jpg
http://img47.imageshack.us/img47/9717/1000623tz5.th.jpg
http://img47.imageshack.us/img47/9742/1000626of0.th.jpg
http://img137.imageshack.us/img137/3...0614006uy2.jpg
As usual the score was growing in pain of my weak Phenom sample....
http://img443.imageshack.us/img443/2...3250httzd7.jpg
With every 10-20 resets I was getting closer to where I wanted to be ....
http://img233.imageshack.us/img233/4...0614386un5.jpg
Finally score worth showing to you guys!:rolleyes:
:party: :party3: :party2: :party:
ORB Link
Summarizing - we can see that CF setup + Phenom is scaling VERY WELL with clock speed! ;)
If only 3GHz would be possible on my sample :p:
PS. Cards clocked conservatively at 863MHz core and 2492MHz mem - Windows XP MCE :)
Update my Score, please :)
Drive 163.75 WHQL - High Quality - 250x11 - 1:1 - 8800GTX com BiosMod 621/1458/1890
http://service.futuremark.com/compare?3dm06=4091683
3DMark Score 10163 3DMarks
SM 2.0 Score 4722 Marks
SM 3.0 Score 4961 Marks
CPU Score 2130 Marks
http://service.futuremark.com/compare?3dm06=3987803
10667
sm2.0 5008
SM 3.0 5395
CPU Score 2120
this is with sp1 build 658 on windows vista ultimate x64 ofc ;>
EDIT: oh single card setup btw
kick-arse, flasker
Lightman, give me your cards!!!
S939 :eek:
That is one nice score for good old S939!!
:up:
Vista x64! That is very good run for that OS!
Push it to 11k ;)
Heh! No problem! Just pop in to my house and grab them, or better bring my your Phenom and Chiller :D
It's not far from Australia, just half a day flight :cool:
Can you say what will it be then?? GF 8800GTX?? :rolleyes:
Eddie, can you update my score.
http://service.futuremark.com/compare?3dm06=4013499
3dmark score 11212
SM 2.0 score 4998
SM 3.0 score 5525
CPU score 2442
3870 at 891/1404
Opty 185 at 3.18G
Window XP 32bit
Wow, nice results with the Phenom. Definately faster then the K8 in this benchmark. Planning to upgrade begining of the year and thought I'd end up getting a q9450, but with some of the results, may go with a B3 Phenom.
Thanks for the compliment, yes its stock volts. I did replace the stock cooler with a TR V2, which does a great job of cooling the card. Depending on the ambient, the load temps range from about 42C-48C. Unless ATI Tool does come out with software voltage control, I'll be volt modding it as soon as I can get a VR.
here's my contribution :)
3DMark Score 11611 3DMarks
SM 2.0 Score 5027 Marks
SM 3.0 Score 5637 Marks
CPU Score 2683 Marks
ATI 2900XT 901/2070 - Amd X2 3525Mhz
http://s5.directupload.net/images/071209/5mlmvw3d.jpg
Very nice score. I'd say that you have the top single card score atm. Great job
