I'm gonna test a 2140 with an Ultra-120 extreme soon.
________
SILVER SURFER REVIEWS
________
You should run 094 and 095 at the same time. See if they are different since you seem 100% sure they are. Maybe other people have the opposite results from which one is correct. :shrug: Last time I did this they were exactly the same, of course the 'reality check' always applies - idle temps can't be below ambient with air or standard water for example.
*edit* Didn't mean the above to sound harsh. I've just tried out Coretemp 094 and 095 with my L2 stepping (:() e4400. Running them at the same time 095 does read 15C higher but also shows TJunction at 15C higher. Don't know which to believe but as long as the temp to tjunction allowance is correct it doesn't matter. The CPU is a poor oc'er anyway :p so I don't really care.
Coretemp 0.94 gives me 6°C idle :rofl: .
Coretemp 0.95 gives me 23°c idle...
My room i currently @21°C, and my water of my WC rig is 22°C.
What do you think is right ?
I just say it to help you guys, you will be looking @ 0.94 and 0.95, YOU all think, ohh I LIKE 0.94, because of the temps ;).
Well , let me say, if you are on 65°c with 0.94 it's actually 80°C ;).
I understand you all why you wanna believe 0.94, but it is wrong.
Look, your are 'hopefully' grown up guys, so pls listen if i say it. I know al lot off guys that where wrong about 0.94 VS 0.95.
Why yoy think its called 0.95 anyway ? Becuase its a new update, and updates give sollutions to earlier bugs...
Just want to say, i've been ALWAYS under ambient temp with 0.94, and i'm not a holy man to break the law of physics :p: .
I hope you understand it now ;) .
Besides that guys, i gonna leave you all, i'm on a E6750 now.
My E2140 is sold, and my E2160 is getting some dust in the closet :P.
But i will keep in touch here :up: .
http://www.ocpulse.com/download/E2140.jpg
Im only using the retail heatsink right now, soon as i upgrade ill push it higher.
didnt have more time to run orthos.. :shakes:
there r 2 orthos & speedfans.. cose i ve posted it twice to "paint"
Screaming results for a dirt cheap chip. I just stumbled across this since I sold my Biostar Tforce P965 and E6300 that was good for 3.4. I was able to buy a sealed EVGA 680i SLI A1 board and for now I got a retail 2140 till Q6600 drops a bit more
My batch code is Q724A014 I am jus wondering what success is with this batch should anyone else have. Pack date is 7/12/07 and its a SLAYJ3
Just waiting on a few other pieces then build the box and see what this chip can do, I will be more than happy with a 100% overclock
here's my E2140 with Abit IP35 PRO under DI
RAM @ single channel and it's A-DATA EE 1200+ D9 GKX
Superpi 8M
http://img407.imageshack.us/img407/5071/e2140475oi4.jpg
Superpi 2M
http://img508.imageshack.us/img508/6175/2me2140hy0.jpg
Superpi 1M
http://img461.imageshack.us/img461/6672/1me2140vb7.jpg
^^ nice clocks, whats your voltage?
A bit more Stock Heatsink action. Ambients around 13c. Getting a little toasty so didnt let her run to long.
http://i224.photobucket.com/albums/d.../prime3510.jpg
Batch: Q713A170
Delta is massive from idle/load. She idle's around 20c, then jumps straight to 65c under load & slowly increases. Better cooler should reduce the massive delta on air.
http://i224.photobucket.com/albums/d...z/idle3645.jpg
C-BuZz
Hi this is my E2160
http://img376.imageshack.us/img376/3227/dsc00284nj8.jpg
http://img174.imageshack.us/img174/3130/dsc00291ny1.jpg
http://img375.imageshack.us/img375/2534/dsc00289nj6.jpg
http://img529.imageshack.us/img529/5029/15656cx0.jpg
http://img266.imageshack.us/img266/3599/m3215dm5.jpg
http://img529.imageshack.us/img529/3978/4ghzon8.jpg
http://valid.x86-secret.com/show_oc.php?id=224070
http://img354.imageshack.us/img354/5228/wr4ghzap8.jpg
call me a n00b or whatever but how come some of you with 2140's have 8x multi and some 9x?
I don't see a 2140 with a 9 multi, only 2160s...please reference a post # for a 2140 with a 9 multi.
Nice clocks there Ming@s, with a L2 as well.
What impact does the lack of cache have in non-benchmarking activities? would you know what speeds these chips need to reach in order to compete with the 4mb cache chips?
update some result, still with L2 rev :D
i've got an M0 my self but havent play with it lately...
E2140 with LN2 cooling
FSB 496 Superpi 1M
http://img74.imageshack.us/img74/5373/4961mqs6.jpg
some pics :
pouring some LN2 to container :
http://img205.imageshack.us/img205/6292/dsc3191ws5.jpg
http://img365.imageshack.us/img365/7365/dsc3233ae4.jpg
http://img205.imageshack.us/img205/7921/dsc3238mo2.jpg
terrible insulation :D
http://img205.imageshack.us/img205/3852/dsc3242zr4.jpg
Amazing job! :toast2: :toast2: :toast2: :toast2: :toast2:
@ trans am
thx bro :toast: :toast:
How to choose the best E2140? which series is the best? Does batch have any influence on overclocking??
my e2140
http://i32.photobucket.com/albums/d2...s/1201mspi.jpg
Specs:
Setup:
e2140 aircooled by scythe zamurai-z with 92mm dc koala.
ip35-e
2 x 512 ddr2 Micron D9
80g WD
550 HEC
on one of ewiz's weekend sales i picked up an e2140 for 66.67$ shipped, does 3200Mhz 1.45 v's 24/7 stable :) 100% OC ftw!
