Anybody try those on the EVGA 680i?? And how high did they go???
My kit arrived yesterday, im still impressed with the firts result (just a 24/7 config).
1200 5-5-5-15 2,1v
http://img146.imageshack.us/img146/7...521vdw9.th.jpg
During the week i will test more configs/timmings etc...
I tested the windows version of memtest and passed without problems :)
A little update:
1m DDR2-1362 5-5-5-15 2,4v
http://img399.imageshack.us/img399/3411/680nj5.th.jpg
Time sucks i know, didnt have the time to optimize anything. I was just proving the limits :p:
Very nice 682mhz for dual channel is :up: How much volt for NB ?
If im not mistaken i putted it to the max (1,55? im not quite sure know). Dont know if it was necessary but i just wanted to make sure that wasnt the limiting factor :)
Tomorrow i will try will less to see if it works. Also i have to try results at cas 3 & 4 :)
Gooooood m****f**kin RAM!
Yes, that was necessary.
I just got to 695 with 2.4v single channel... damn you 700mhz!
My p5k is quite a bit more stable then my p5b dlx
Thats with almost no tweaking tho im sure i will hit it soon.
Today ive been testing C4 and here are the results :)
32m DDR2-1000 4-4-4-12 2,1v
http://img225.imageshack.us/img225/1...v32mvl9.th.jpg
32m DDR2-1100 4-4-4-12 2,25v
http://img225.imageshack.us/img225/7...v32mjx6.th.jpg
32m DDR2-1200 4-4-4-12 2,55v
http://img225.imageshack.us/img225/6...v32mow0.th.jpg
hey guys.. anybody use memtest86+ 1.70
hope this kits pass ddr2 1200 with timing 4 4 4 12 to memtest86+ 1.70.. :D or I'm just dreaming.. :)
With my kit its relatively the same. cas 5 1200 is piece of cake but at cas 4 look at my captures, the big jump i had to do with voltage to make them stable (32m did not try memtest) at 1200.
At 1100 2,25 was no problem but at 1200 i had to jump to 2,55v to pass the 32m test, and ive tried all the voltage levels in between.
Today i will try cas 3 settings, and for the quick look i did yesterday it seem that it will be necessary too a lot of voltage to make them stable at a decent speed.
Looks like cas 5 is the nice spot for these kits, atleast for mine.
Well guys, even with one module it has been a pita but finally i did it :p:
Another member in the 700mhz club :D
1m DDR2-1400 5-5-5-15 2,55v
http://img520.imageshack.us/img520/1...001mpf6.th.jpg
Heres the cpu-z validation
http://valid.x86-secret.com/show_oc.php?id=209916
Another update with extremely low voltage :p:
32m DDR2-1000 5-5-5-15 1,8v
http://img401.imageshack.us/img401/7...v32mor4.th.jpg
32m DDR2-1100 5-5-5-15 1,9v
http://img401.imageshack.us/img401/9...v32mqk9.th.jpg
I guess my Ballistix can do ddr1200 at low volts too:D ... I got 4 stix and these are the worst 2, 5-5-5-15 and subs were set at auto in bios... mobo is Abit IP35....
http://www3.telus.net/luis99/ddr12002.1.JPG
Not too bad for Ballistix Pc 5300:D
Hmm just want to tell my BallistiX is dead, not ALL Dead in om them right now..
i must have 2.3 vdimm for even have to get them to boot... and 2.4 för stable windows.
and i dit push 2.2-2.3 trough them 24/7, and benched them for a shhhorrt while at 2.6 and 2.5 ....but not long max an hour...sooo they are soon a gooner :) buhuuu... 3-4 months old!
regards.
Thats the same that happened to my Cellshock 1000 and my Crucial 10th anniversary, now they need minimum 2,3-2,4v to boot.
All the test i did with my 8500 with high vdimm were using a 9cm tornado upon them and the ac at maximum (14ºc).
For short benches i use high vdimm but for daily use i never pass 2,1v.
Dont want to loose another good kit of memories.
Hmm well they are workin at this vdimm, soo maybe they will survive at this?
just that it has turned up a notch?
Lets say iam staying at this vdimm? will they still die? hehe
kind of stupid question maybe, but i have to learn some time :)
