We definitely need to wait for retail samples reviews from XS members to get the whole picture, who's gonna bite the bullet first, i will let the dust settle before i jump on the bandwagon. And thanks for the info Victorshen.
Quick test on new ATI new GC
http://forums.hardwarezone.com/showthread.php?t=1607936
3DMark and' insufficient by now it needs to see under the games to parity,' of bases as they involve the two cards.... he/she asks her and' how come you/they don't make to ever see a test under the same game, since do these seem truthful?? You excuse the possible erred translation...
P.(Italy):slap:
il 3DMark e' insufficiente dopo la storia dell' AA che perderebbe gia a 3x il 15% delle prestazioni, bisognerebbe vedere sotto lo stesso gioco a parità' di piattaforma e di impostazioni, come si comportano le due schede....
La domanda e' :come mai chi ha la scheda non fa mai vedere questo confronto almeno su un gioco ???
saluti
P.:toast:
^^ ARGH :O, I don't speak Italian!!!
3d mark is not enough because of the fact that the AA will make a loss of 15% overall performance, it is needed also to bench the same game with same platform and settings, to analyze how the two cards bench...
The question is: why who has this ''uknown'' card never shows this kind of camparizon between GPUs in one or more games?
That's how'd i translate it! Fear not non-italian-speaking users!:D
http://forums.hardwarezone.com/showp...9&postcount=33Quote:
ok dokey. upon request by many.......
compare the 8800GTS 640Mb from Leadtek as comparison.......
it's on the shelves here in malaysia
about lets see about usd 500
Anything new?:toast:
X6800 @ 2,93 GHz, Asus P5W-DH Deluxe and Radeon HD 2900 XT with default cooler:
http://www.io-media.fi/sampsa/hd2900xt/oc_01.jpg
http://www.io-media.fi/sampsa/hd2900xt/oc.png
http://www.io-media.fi/sampsa/hd2900...rk06_11676.png
3DMark06 stable 855/1030 MHz.
Next I'll switch to QX6700 and DFI's RD600 motherbard and DI is coming on Thursday.
It will be interesting to see max result on air cooling. Also, if understand it correctly the GPU gets rather hot? I wonder how DI can handle that...
Thanks for sharing! :toast:
first run LN2 no mods
dfi p965 s dark- ocz fleex 1200 -jetway hd 2900xt -x6800
http://download.pctuner.net/upload/r...4546_28790.jpg
Dammit, I just wanna see what's possible for 24/7 on decent water, including power figures.
Soooo now that the NDA is lifted, where is all the information?
Here we go, unfortunately this Thursday was public holiday here in Finland so I'll get dry ice next week:
http://plaza.fi/s/f/editor/images/0519_r600_dia1.png
According to AMD's document R600's recommended maximum operating temperature is 105 Celsius and 125 C is the absolute maximum. Beyond this ASIC will be damaged.
http://plaza.fi/s/f/editor/images/X-...9142802406.jpg
R600 XT GPU TDP is 160 watts and each memory chip two watts = total board TDP 225 watts
http://plaza.fi/s/f/editor/images/0519_r600_oc1.jpg
Shim is little bit higher than GPU itself so a friend of mine made 1 mm copper cold plate for better contact. Unfortunately shim is glued very tight around the R600 and very hard to remove with razor blade. G80's heat spreader is very nice feature when installing container.
http://plaza.fi/s/f/editor/images/0519_r600_oc2.jpg
Here is my aluminum solid container installed on Radeon HD 2900 XT. I modified heatsink from Radeon X1800 XT to PWM components.
http://plaza.fi/s/f/editor/images/0519_r600_oc3.jpg
Graphics card installed to test setup: QX6700, DFI RD600, pair of Corsair XMS6400-C3 and Enermax Galaxy 850 W.
Tests next week :toast:
Seems like you're gonna have fun, looking forward for your results.
Sampsa--This may be a rather mundane question...
When using that copper coldplate, do you apply thermal material inbetween both contact areas of your block(s) or just inbetween the GPU/coldplate?
And for those of us who aren't machinists, where could we pick up a 1mm piece of copper like that? Lowe's or Home Depot, possibly? Does anyone know the exact specifications of the shim area?
