Damn i knew it...
Non of my joints were faulty, the leak is somewhere in the A/C unit, i suspect the condenser...
Thats gonna be at least one week of finding it, buing a new condenser (IF i will buy a knew condenser beacause this stuff is so expensive i dont think ill have the money).... §§§§
1 Attachment(s)
Its a good ocassion to post some pics of my compressor:
First the model number
1 Attachment(s)
1 Attachment(s)
1 Attachment(s)
Accumulator ---> comp. connect (a 12mm copper pipe)
1 Attachment(s)
The rubber stand on wich the compressor stands (its very flexible and when you push the compressor a little it "flows")
1 Attachment(s)
The compressors:
On the left the Danfoss SC10B, R12, LBP, 250W engine wich will be used in the II stage and on the right the Sanyo from the I stage
dayum how much did those suckers cost u
everything costed me in total 750zl...
the compressors costed me about 400zl total... thats ~100$
Damn, §§§§, §§§§, i cant find that mother §§§§ing leak and its making me crazy :brick: :brick: :brick:
i dont have any R22 left, the system is in bits beacause of ONE §§§§en leak :brick: :brick: couldnt it occur on one of the easy sericeble parts ? like the connection between the filter and the pipe or smth like than, NOOooo it had to be the condenser :brick: :brick:
damn take some pics of it lol i wana see the fury its causing!!
1 Attachment(s)
If ill find a leak and if its gonna be only one leak ill simply take some fins of it, sand the pipe to clear copper (with a sander) and seal it... but i dont even dream that it will be so simple, think about multiple leaks...
1 Attachment(s)
1 Attachment(s)
u could drop the thing in water and see were the bubbles come from ;)
Great Minds think alike:D
there is always the soapy water trick, im sure you know about that one by now. ive heard of some people dumping their entire system in a swimming pool, which sounds like a great idea if you have access to a swimming pool.
Ive cleaned it with water... this condenser is hopeless... Im thinking of buying a one for a car, its about the same size and 3 times thicker...
Ok, found one, 5x more efficent :D it costs 100$ and its gonna be some REALLYYY hard work convincing my dad to buy it :D
1 Attachment(s)
During "free" time ive made smth. for my cascade/computer..
A new baseplate for the mobo etc. :D
The construction:
1 Attachment(s)
The wood is 2cm thick and absorvs sound very well
The sound mats:
1 Attachment(s)
1 Attachment(s)
1 Attachment(s)
Cost:
-1$ Wood
-0$ Sound mats (made out of packaging materials)
Total cost: 1$
Effects:
Completely inaudeble Western Digital WD800JB :D
Love the Antec True Power 480W, its so damn quiet.. Love this hdd also its very quick but works like a chain saw...
The computer in total is now completely inaudeble, fans works @ 5V and dont produce any sound (hand picked- the only thing my computer wich is hand picked :D)
sweet howto/walkthrough!!! :slobber:
to bad the compressor broke down, hope you can get a new one.
