I just meant so you could go for max clocks using CAS 5, you're board/cpu limited on that AMD setup IIRC.
My OCZ cas3@1216mhz with 2.16v :( .Will buy Amd 5400 BE and try to hit cas3@700mhz :confused:
http://farm3.static.flickr.com/2178/...730888e6_o.jpg
Cpuz valid
http://valid.x86-secret.com/show_oc.php?id=359641
x.5 multis give bugged RAM speeds, you're nowhere near 600MHz ;) I'm guessing 320MHz.
600MHz C3
End!
One stick is now faulty, please don't ask about voltages...
Thats 560 mhz,not 600 :confused:
Oops
600MHz 3-3-3-9
END!
Hi guys,
here are some results i was able to reach with my lovely OCZ Reaper :)
After beeing limited by my 680i LT Mainboard, i just grabed a pencil and did some little mods at it.
SuperPi 1M - 537.1Mhz CL3-3-3-2
http://www.freeocen.de/wbb2/attachme...achmentid=1053
Validation - 545.2Mhz Cl3-3-3-8
http://valid.x86-secret.com/show_oc.php?id=418952
Specs:
OCZ Reaper PC6400 CL3-4-4-15
XFX 680i LT @ P32 Bios
Vdimm=2.67(BIOS Reading) / 2.73(DMM)
SPP-Voltage=1.62V
i do not believe the amd valids or screenshots. theres a bug i will say. what kind of cooling did you use?
wondering if this club is reserved for 1 gig or more sticks only - i have some pretty epic older fat body corsair sticks around that i wouldn't mind running on a death mission - these puppies do ddr2-1100 at cas4 at pretty low volts
Dont think I posted my old result here..
Motherboard: DFI LP DK X48-T2RS
Processor: E8400
Memory: Crucial Balllistix PC8000 [2.2V Stock] @ 512MHz with 2.95V
http://valid.x86-secret.com/show_oc.php?id=371093
Didnt try Pi1M as I was just aiming for highest possible. 525MHz [3.0v] file was corrupt as I as usual tried 530 right after that.. GREED :D
Well this afternoon I tried my RAM on a Commando... Boot at 500MHz C3 2.9v, SetFSB up to 510MHz and Pi . Any higher would lock up around iteration 3. Like an idiot I tried more than 3v and *sigh*
This isn't the first time they haven't booted after being abused so I'm holding thumbs :up:
@ Natedog, all AMD results on a 4.0 or x.0 multplier are bugged as AMDs don't have CPU/4 or CPU/x.5 dividers. AMDs calculate the RAM speed from the CPU speed, unlike Intels which calculate it from the FSB. ;)
I don't know what to make of the 680i result though. If it's correct his RAM is even better than mine :\
:banana: It works again :banana:
One fairly long BIOS clear later and I could boot again, so straight back up to 2.46v real and I got his quickly:
http://valid.x86-secret.com/cache/screenshot/421384.png
Validation - 504MHz C3
It says 4-4-4-4 in the validation
Very strange. I'll take a photo tonight :up:
Just the typical heatpipe of all ocz reaper modules and some case fans.
For more voltage i will probably put a little fan dircetly on the ram, but anyway this would be only for validation and not under load :)
650 3-4-4-x SC.
These sticks are very volt friendly, three trips to almost 3v with no bad side effects :p:
650 CL 3 is insane, happen to have link for that? You are very lucky with those sticks, I have seen some D9's (Ballstix 8000's) degrade after 10 mins at 2.45v with an 80CFM fan on them. Do you run yours with or without heatspreaders?
I have a spot cool on mine is this good enough for 2.6v~ and 24/7 life?
With. I've destroyed three sticks of BH-5 removing spreaders :(
I used DI for cooling.
Original French Link
Google Translated
LN2 cooling, P35 so no CAS/Memset bug :up:
