anyone else getting a weird warning message after inital post...
Warning: Hardware ROM or something..so fast I cant fully read
I have no raid and I disabled the promise raid in the bios..does not occur every boot
RAID user here and nothing like that on POST.Quote:
Originally Posted by nealh
I had plans for using the Swiftech MCW30 myself. After offering it up & seeing it a bit "rocky" without any tubing attatched, I could imagine the Tygon R3603 3/4" tubing bends, forcing the block over the edge of the NB Core. I really hate that Glassy Scratching sound! ;)
The New DD should offer a solid mount.
DD-RD600 Xpress 3200 Chipset Block
thanks..any no RAID usersQuote:
Originally Posted by STaRGaZeR
Aquacool Watercooler are very good for DFI.
This it for NB
http://www.pc-cooling.at/product_inf...roducts_id=876
And this for SB (not 100% sure)
http://www.pc-cooling.at/product_inf...roducts_id=864
What program are u using to clock in windows ? Is there any memconfigurator for windows aswell ?
There are a number of programs available to clock the ICFX3200. I was able to work with abo to create a SetFSB program for it. It is available here:Quote:
Originally Posted by Turbodream
http://www13.plala.or.jp/setfsb/
The other program, which can control FSB and memory clocks as well as memory timings (except for CAS latency) is AMD System Manager. It should be on your driver CD included with your ICFX3200. If you don't have it, you can download it from here:
http://us.dfi.com.tw/Support/Downloa...FLAG=A&SITE=US
Hope this helps.
With AMD System Manager i cant change my memorytimings. Seems disabled or something. Do i need to change something in bios ?
Thanks for the tip of setfsb by the way :clap:
Before the change dimm parameters click the refresh button thats all:DQuote:
