Originally Posted by uberowo
Well, I removed two RAM modules and was able to run memtest about 25 minutes just fine atleast.. which is progress..
In windows now running the StressCPU test in Orthos on all 4 cores.. Been running for 10 minutes (at STOCK cpu speed mind you) and my PWM temps are as high as 142 degrees.. This with an extra 90mm fan hanging a couple of inches above my CPU waterblock.. (Without this fan they are 100-110 degrees idle.. with the fan they are usually 60-70 degrees idle.) CPu temp is 38-39 at this point and system temp is 48.. All according to the uguru software from Abit.
This is poor engineering** imo!
**Disclaimer: I know nothing about engineering.
