Can I join with E6400 and two speeds? I have incredable stepping, very low voltages..
3800 at 24/ is quite possible for me , as my chip is capable to run at that speed at 1,5 V Core, which is acceptable.Quote:
Originally Posted by argonmtt
And the temps are below 69-68 C, which is OK for the Conroe . But- why ? ;) The output diff is small..
Yapp - agreed, here is a screen from my last session with the L629B @4GHz. It´s something over 5h Dual-Prime stable, then i had to stop because i needed the testbed for some 3060`s :toast: :Quote:
Originally Posted by famich
http://img158.imageshack.us/img158/9...m167rj4.th.jpg
It shows that 4GHz with simple water is possible, with some tweaks it should be no problem to get it 24/7 stable - if you do not care about the temps around the borderline ... lapping could help to get the temps down a bit too and - as last resort - chilled water could do the trick also, but i`m happy with the 3.9GHz i´m running the cpu now 24/7 :clap: and now let´s have a closer look at some 3060´s :toast:
:toast:
Way to go, Pete ! :clap:
User Name:VicFalc09
Stability: 8 hours 44 minutes orthos blend
CPU name E6400
OC: 3200 MhZ
Stepping: 6 b2
Week: l626
Vcore: 1.3250v
Cooling: Air
Cooler brand/model: Zalman 9700
Motherboard: Asus P5B Dlx
Bios Version: 0804
Operating System: xp 32 pro
RAM brand: G.Skill
RAM rated speed: DDR2-800
RAM actual speed: DDR2-800MHz
Latency: 4-4-4-12
http://img411.imageshack.us/img411/3996/untitledzb6.jpg
Where do I go from Here?!?
User Name: Spookz
Stability: Orthos Blend 11hrs+
CPU name: E6600
OC: 3204MHz
Stepping: 6 B2
Week: L631
Code: A500
Vcore: 1.325V (Bios), but Probe Shows 1.36V
Cooling: Air
Cooler brand/model: Scythe Ninja Plus Rev.B
Motherboard: ASUS P5N32-E SLI
Bios Version: 0501
Operating System: XP 32
RAM brand: OCZ
RAM rated speed: PC4300 (Value Ram)
RAM actual speed: 667MHz
Latency: 4-6-6-16 <-LOL, i'll work on them...
http://img239.imageshack.us/img239/2...0stableeq7.png
I've got my E6600 up to 3.6GHz (400x9) on the P5N32-E SLI now.. But my cpu is running SOOO hot! BTW i'm on air cooling in a fairly hot room..
Still on OCZ DDR2-533 Value Ram.. =)
Probe is showing 63-64C IDLE.. i don't dare touch any full loads like Orthos..
It's not safe right?
User Name: Comminadian
Stability: 10 Hours Orthos
CPU name : Xeon 3060
OC: 3609 MHz
Stepping: 6 B2
Week: L628
Code: B299
Vcore: 1.38v @ Load (1.41v idle, 1.450 BIOS)
Cooling: Water
Cooler brand/model: Koolance/Exos-AL/CPU-300G
Motherboard: Asus P5B-Dlx
Bios Version: 0804
RAM brand: G.Skill
RAM rated speed: PC6400
RAM actual speed: 802 MHz
Latency: 4-4-4-12
http://img329.imageshack.us/img329/9...croppedio7.png
As long as you're loading under 80 it's ok. I've had my D820 @ 75C for ages on the boxed cooler. Tried lapping the CPU already? :)Quote:
Originally Posted by spookz
LOL.. i dont quite wanna void warranty yet.. =)
I'm waiting for ASUS to get their act together..and release a proper bios for the P5N32-E SLI... atm if i set anything at like below 1.4V Vcore.. it'll default to 1.39V in Probe... so.. it's kinda locked Vcores.. =S
I hope they can release a fixed bios..so i can adjust the vcore step by step..=)
Until then...ahh....
Orthos blend priority 1 is no stability test....
Try custom (small ffts in place) and prio 9! You'll see the difference...
User Name: Stx
Stability: 8 hours+ Orthos Blend
CPU name: E6400
OC: 3200MHz
Stepping: 6 B2
Week: L626
Code: A288
Vcore: 1.3125V(set in BIOS-vdroop to ~1.26 from mbm5)
Cooling: Air
Cooler brand/model: Tuniq Tower 120
Motherboard: Asus P5B Deluxe
Bios Version: 0804
RAM brand: G.Skill
RAM actual speed: 800Mhz
Latency: 4-4-4-4
http://img406.imageshack.us/img406/9...2751pm1iq6.jpg
User Name: Chri$ch
Stability: dual Prime (9 hrs, 6 min)
CPU name: X6800
OC: 3500MHz (500x7)
Stepping: 5 B1
Week: L617
Code: A954
Vcore: 1.33v (idle & load)
Cooling: Water
Cooler brand/model: Zern PQ
Motherboard: Asus Commando
Bios Version: 0601
Operating System: Win 3k3 Server
RAM brand: Cellshock
RAM rated speed: PC-8000
RAM actual speed: 500
Latency: 4-4-4-12 2.19v
http://www.muenster.de/~e30pics/Bild...-1/Prime-4.jpg
user name: burn what?
stability: 15+ hours prime 95
cpu: E6400
oc: 3.6 Ghz
stepping: 6 B1
week: L628
code: B179
vcore: 1.425 set in bios
cooling: air
cooler: zalman 9500
motherboard: gigabyte ds3
bios version: f8i
operating system: win xp pro
ram brand: patriot
ram rated speed: ddr 800
ram actual: ddr 900
latency: 5-5-5-15
stupid question time, with the 200kb limit on picture uploads, how is everyone posting these large screenies that look crystal clear?
Imageshack.usQuote:
Originally Posted by burn what?
User Name: Babalouj
Stability: 12 Hours+ Orthos blend
CPU name E6600
OC: 3600mhz
Stepping: 6 B2
Week: L632
Code: A734
Vcore: 1.46V
Cooling: Water
Cooler brand/model: Swiftech 6002a
Bios Version: 0910
RAM brand: Crucial
Latency: 4-4-4-12
Now can i get my spot
User Name: menlatin
Stability: 15 Hours Dual Prime Blended
CPU name E6400
OC: 3901mhz
Stepping: 6 B2
Week: L628
Code: B194
Vcore: 1.56V
Cooling: Water
Cooler brand/model: Swiftech Storm Rev1
Bios Version: 0711
Operating System: XP 32 Sp2
RAM brand: Patriot
RAM rated speed: PC5300
RAM actual speed: 988
Latency: 6-6-6-15
http://i89.photobucket.com/albums/k2...901prime-1.jpg
Dual prime @ 3900 with a 6400 on water is remarkable. Could be used as a standard itself. This was on the front page though and not that I'm trying to take away but it needs to be clarified maybe. "The Screenshot must have orthos running.. Idle or crashed results will not be included from now on." Is that for orthos only? I will try, won't do dual (my ver. has an instance for both cores)or more than 8hrs though. I want to use my board. Congrats on your run.
http://thasp.net:4000/pictures/computer/stability.PNG
e6400(I will post the stepping later, I wrote it down I just don't know where) @ 1.45v
G.Skill DDR2 1000 4-4-4-12, 2x1 GB
Gigabyte DS3, F5 BIOS from late september
Windows XP SP2 pro
Check the other pics in that directoryfor the cooling and the rest of the computer. The details are, rebranded laing d5 pump @ 8.35v, swiftech mcr320 radiator, aquaextreme mp05 waterblock, swiftech mcw30 northbridge block, a mix of thermaltake/zalman vga ramsinks on the mosfets next to the CPU and the stock e6400 heatsink's fan over it. All fans attached to a sunbeam fan controller(including the pump).
3.8 is a bit trickier, I'll have to try more later, but the voltage increase is definately not worth it.
LOL I got relegated to the E6600's... mines a 3060 though! ='(
edit:pm sent
User Name: buckshot
Stability: 10 hours + Orthos
CPU name: E6600
OC: 4300 MHZ
Stepping: 6 B2
Week: L630
Code: A844
Vcore: 1.58
Cooling: Phase
Cooler brand/model: Modded VapoChill LS (Thanks! Jin)
Bios Version: 0908
RAM brand: Crucial 10th Anniversay
RAM actual speed: 1060
Latency: 4-4-4-15
User Name: Comminadian (Replace my other entry please)
Stability: 8 Hours Orthos
OC: 3600 MHz (450x8)
Stepping: 6 B2
Week: L628
Code: B299
Vcore: 1.39v @ Load (1.42v idle, 1.4750 BIOS)
Cooling: Water
Bios Version: 0804
RAM brand: G.Skill
RAM actual speed: 900 MHz
Latency: 4-4-4-12
http://img209.imageshack.us/img209/1307/450x8pp5.png
EDIT: Delete this post
User Name: Mongoose420
Stability: 10+hours orthos blend
CPU name E6600
OC:3600mhz
Stepping: 6 B2
Week: L632
Code: A734
Vcore: 1.43v
Cooling: air
Cooler brand/model: Theramltake Big Typhoon vx. Custom backplate and bolted through
Motherboard: DFI ICFX3200 T2R/G
Bios Version: 12/22/2006
RAM brand: Crucial
RAM rated speed: PC8000
RAM actual speed: 1010mhz
Latency: 4-4-4-18
http://img267.imageshack.us/img267/9...core6nx.th.jpg
