Originally Posted by Khaotic
I would, but i put the new BIOS chip in the board - and the board is still dead. STUCK at CPU INIT. I've got an RMA# to send this back, and i plan to send it back with the origianl BIOS chip, keeping the new one here on the desk. However - If someone knows how to make this go away so i can USE my SLI comptuer - it woudl be great.
Yes, I've tried the battery trick. I've had it out for going on 48 hours.
What position should i have the CLEAR CMOS JUMPER and BUTTON in? I've gone back and forth on that that -
I pulled the water block off and kept a finger on the CPU while i booted the comuter. It took it probably close to a full 50 seconds before the CPU even began to felt warm.
Yes - CPU INIT is stuck on the back LCD screen. I even pulled every card, the IDE connector, the memory, AND the CPU - and still CPU INIT on the LCD.
Unless someone else can recommend another 680i board, I'll just hot swap this board - buy another and sell the RMA board when it comes back. It HAS to be a 680i - becuase i already have two 8800GTX cards - and I want to run SLI. And, going to an AMD chip is ABSOLUTLY out of the question.
