I'll ask again........:rolleyes:
Any ideas as to why the voltage sensors and system temp ain't working on mine? or do they not work on my board with MBM5?
Originally Posted by scaramonga
mabey you should use search :rolleyes:
http://www.xtremesystems.org/forums/...d.php?t=125201
this thread is about the c2 dts plug in not mobo mbm support thread
I posted the link to the plugin for ur board before, why not ask there? ;)
Well strike me down and beat me with a pole guyz........:rolleyes:
I asked.....never searched.....but I got :D
Many thx :toast:
Thank you for indentifying this problem. I believe I already know the source. I will work on a fix for this to be included in the next release (1.2?). I'm working with Alex, maker of MBM5, right now. Looks like we are going to put out an Update 3 to MBM5 to be hosted from The Tech Repository.Quote:
Originally Posted by Millyons
-FCG
currently im just gonna set to user startup instead of system as a work-around....but it would be nice for it to get fixed......ps: will you send me 1.1 ? ;)
i dont wanna clog the post with simular screens but, all is well with 1.1 and cpu usage.
Correct spelling of "exhaust" ;)Quote:
lol thanks i never even noticed that :)
Off topic here.....
If I install the Asus plug in for MBM-5 settings I need to replace the Data folder in MBM.
Now.... if I want to display clocks and temp offf my GPU I have to replace the Data folder as well. Is this possible to do?? How??
TIA.
FCG noticed a bug with my system (see sig), the CPU speed does not update. I'm NOT using the CPU usage, but when changing OC settings inside windows, using the Gigabyte utlity, the CPU speed doesn't change.
My plugin provides core temperatures only. All other functions are provided by MBM5 directly. Starting with version 1.1 (to be released soon) allows for simultaneous core temperature monitoring and CPU usage displays.Quote:
Originally Posted by qdemn7
-FCG
OK, thanks.Quote:
Originally Posted by freecableguy
mbm actualy aways was flakey with showing cpu speed, but this time its not to blame, if you noticed most programs don't show when u change cpu speed in windows, core temp, orthos, etc...Quote:
P5WDG2 WS Pro, E6600 - CPU load and core temp for both cores read out perfect on my Matrix Orbital MX412. Thanks a ton ! :toast:
edit: simultaneous
where can we get the version 1.1?? I've tried twice with v1.0 and just get some pop-up box saying something about DTS. Someone else posted a pic of the warning message a few posts back.
What am I doing wrong??
Is 'Winbond 1' the correct sensor for the system temperature? :)
Thx for this prog, i'm gona try it asap:)
Can't get it working:mad:
I'm getting a strange pop-up screen when starting MBM after installing the plug in as in your post (v1.0). It says something like DNS core temp error???
There is no plug in option for core temps shown when I right click MBM in the tray.
I've completly removed the latest version of MBM5 now and tried again.... same error?? Core temps 9 & 10 are 0C when set to custom and I have disabled CPU usage??
Any ideas?
right click in the tray and click update CPU.. it generaaly will change the CPU speed. GPU and clocks will not update if you have that plug in installed.Quote:
please check your PMs. you seem to be experiencing an as of yet unfound problem. thank you.Quote:
Originally Posted by cdelong
-FCG
is the error like in this post?
http://www.xtremesystems.org/forums/...&postcount=150
Wonderful work FCG,and all those involved with making this happen. Thank you for giving the best monitoring software of all time a new lease on life.
Yes... that's the one.Quote:
I'm the only installed user on my rig though. Fresh OS install, MBM5 5370 and that message:mad:
