Originally Posted by el rolio
ps: i was thinking, some of this teasting does need to be cpu loop only with a SMALL midrange rad. like a 80mm rad. the reason being, if you test 5 waterblocks with a PA 120.3 and yates @ 12v for example, it would seem to me that the rad would do a lot of the work and bring results very close to each other. whereas with a much more simple, low performing rad, but with constant heat load, ambient temps and only variable flow, maybe then we could see some separation in results?
anyway just some musings.
