My HD bench from my Abit IC7-G mobo. 2*80gb sata maxtor diamondmax plus9 in raid0 via mobo. 70k thats ok i think.
lucky there nikh. my max3 was doa. wouldnt let me oc my 3.0c past 3.3ghz LoL
I never been invited to a lan party. I think I am the only guy in my school that built his own computer or is it just that i hang out with the "cool" people. weird
very powerful cpu and mainboard
my 3.2c chip will do 3.85 on just water going to put a Vapo in it this weekend :)
great post your results as soon as you do it
why vapo :( why not a prom? (hehe :D )
I've been pretty happy with my IC7-G so far. My last 2.8C saw 275fsb on an MCX4000+T, and my new one hits 250fsb on just 1.55vcore. I benched my last 2.8C at 262fsb and managed a 3DMark03 of 6688 I think with this 9700 Pro from OC System.
I pushed the last one to 280 and killed it though, so I wont be pushing this one any further than 255fsb. Thats still killer on an air cooled pelt system though I would think. I havent seen anyone else have this sort of luck with CPU/mobo combo, but then again, I dont get out much these days and look at the forums to see a lot.
I am curious as to whether anyone else has been able to get a 2.8C to OC that high on such low voltage. It kinda bugs me in a way, because I'm not used to having one that "doesnt" require at least above the 1.6vcore range.
System specs:
IC7/IC7-G bios rev 18
P4 2.8C @ 3.5
GeIL PC4000 Platinum 512 megs
ATI 9700 Pro Level 2 from OC System
Vantec Stealth 520A
Meawell S320-12
Maxtor 30gig ATA/133/7200rpm
ASUS 50X
Sony Floppy
MCX4000+T w/92mm Vantec Tornado-variable speed controlled
CPU: 250fsb @ 1.55vcore
AGP: Fixed (66/33) @ 1.6v
Mem: 5:4 - timings 2/3/3/6 @ 2.7v
CPU Temps:
Idle=15C
Load=34C
System Temps:
Idle=26C
Load=32C
PWR Temps:
Idle=26C
Load=30C
You don't understand how much I regret it I wish I would of got Dual Mach II with r404a mods :)Quote:
IF I did have dual Mach II's with r404a I would buy a 3.2EE in a heart beat :)
I get pissed off everytime I think about it.
I am off to choke my wife because Crash made me remember :banana:
which vcore an which vdimm does your abit boards provide?
which is the lowest vcore you can set?
which ram dividers can you choose? cause i got a 2,0-mobile D1 which is set to 12x100. and my fuc**** albatron gives me only 3:4 divider
ABIT IC7 & IC7-GQuote:
MAX VDIMM 2.8
DIVIDERS:
1:1
3:2
5:4
Hi My 3.0C goes up to 4.230 Ghz Stable, benchable and 4375 goes down after 3 or 4 minutes.. :)
Cooled by Prometeia Mach I. I´ll just reboot and "turn" my storeage disk on. The you will get proof. :)http://frip.dk/jacobhansen/4375%20Mhz.JPG
Max3 is limiting me - P4C800-E Deluxe on the way. I'm getting 4.0Ghz right now - but this chip has a lot more left in it, I got 3.8 on stock voltage . . . :)
http://server5.uploadit.org/files2/020104-ouchy.JPG
on air with a silent zalman flower @ 2000rpms
Which temps do u guys get with watercooling with the abit ic7/-g/-max3 ?
This is the lowest temp which i get with waterkoeling (air = -1)
http://www.animecore.net/ownage2.jpg
http://www.i-ssential.nl/testarea/knoeipot/3.8.jpg
p4c3.2@240fsb 1.7v
p4c800-e deluxe
2x512 corsair 4000 pro 3-4-4-8 2.75v
I couldnt get above the 3.8 :(
any thoughts or advices?
