my pethetic "see this thread and do " attempt. not actually that hard :D
corsair xms2 6400 C4, gigabyte DS4
http://img110.imageshack.us/img110/5760/242cq7.th.jpg
CORSAIR 8500c5@2.6vdimm
B1 chip is pretty much maxed on the 1m, ram/board should scale with some more vdimm at these clocks with a better chip. Untweaked clean 2k3 install used for both runs:
http://www.overclockingpin.com/95sec...test%20p5b.jpg
http://www.overclockingpin.com/10min...0untweaked.jpg
Very nice clocks and times; actually the difference between B1 and B2 chips appears to be really significant for 32M runs.
P5B E plus mod l Corsair PC5400 l @600 4-4-4-12 l Vddr = 2.73v :D
http://valid.x86-secret.com/show_oc?id=167708
a value ddr2 with hynix c4 chip that run over than 600 @ 2.4v.....it cost me about $100 for 512*2
Validation link : http://valid.x86-secret.com/show_oc?id=136647
Screensyut:
[img]http://img457.imageshack.us/img457/5499/3048chinoa32m175vbd2.jpg[/img
welcome to XS Pejantan :D... but as you see at the first post, only P965 and 975X chipset allowed :D.
i didn't actually bother testing much but i should have and since sold themQuote:
Originally Posted by loc.o
i did try to test them with tight subtimings with no gain so i assumed that the mobo probably couldn't handle it
well that was a mistake as i got some el-cheapo RAM which ran past 630MHz which got me thinking to check HZ sticks on 680i as i had them installed on my benching rig and bang they jumped from 550 4-4-4-x to 625 5-5-5-x
yeah it is.......that's pretty bad considering the RAM clocks at such high MHz...this is the first time i've seen anyone bench RAM that high past 5Ghz good on ya KP :DQuote:
Originally Posted by before
OMG !!! it was a silly mistake......sorry mr benny n all..... i'm too lazy to read the rule....Quote:
Originally Posted by Benny Lodewijk
Join in with DFI Infinity 975X/G
http://valid.x86-secret.com/show_oc?id=168046
http://www.indoupload.com/reg/images...fi975xpi1m.JPG
Very nice indeed!!!Quote:
Buffalo PC6400 Cas 5
http://daftou59.free.fr/Screen/Buffa...s5/Buffalo.png
D9GMH :banana:
E6600
Biostar Tforce P965
Vdimm : 2.2v
http://daftou59.free.fr/Screen/Buffa...M_625_2.2v.png
I think I'm limited by the motherboard :slapass:
Hello to everyone here
chipset 975
one stick of the OCZ 1150 valid link at 630 MHz (DDR2-1260)
http://valid.x86-secret.com/show_oc?id=158351
and 1M at 625 MHz (ddr2-1250) all on air cooling.
http://img263.imageshack.us/img263/3...hellwj9.th.jpg
http://img444.imageshack.us/img444/1...test4rn.th.jpg
I just tested a b2 clock for clock setting for setting on p5b against that b1 chip and the difference in time was nearly 28seconds faster! So that 10min11sec 32m time can be 28sec faster at those clocks..wow.Quote:
Crucial 6400 1290mhz -Asus Commando
http://img170.imageshack.us/img170/8577/imagem4cc9.jpg
Here is a little better one with b2 chip :D .This time 6400 c3's..not finished just yet with 32m and still untweaked OS:
http://www.overclockingpin.com/9min4...0untweaked.jpg
@KP
....youre a sick sick man:D ...wow....:clap:
...impressive results mate...
that's much better :DQuote:
Originally Posted by k|ngp|n
now tweak that OS man
did you use largesyscache at least on that run :eek: and since you're on that mobo surely you used Core1 Affinity :D.....if not man oh man there iwll be some killer scores coming up soon
is your CPU or RAM topping at at those speeds or none :D
Looks really good! :clap:Quote:
You may wish to try with Win XP theme (under 2k3 of course); it uses to be faster to me ;) A 'small' tweak with 'big' gain... :)
Anyway, your run and RAM are very impressive. No doubt about that! :toast:
What bios are you using?
lol you're joking heheh :) how big is bigQuote:
Asbolutely no OS file/reg tweaks used. No ramdisk, no maxmem, no realtime, no copy waassup ;), nothing. It would be cooler to break the WR with just straight up overclocking....then I'll tweak it downQuote:
Originally Posted by dinos22
What is core1 affinity again?? In task manager? Does it really work with core2?
Ram and mobo def not maxed out. Using 1.88v on the chip in that last 32m and it can still go about 20c colder before it locks, so maybe there is more, we'll see :D. That was first ln2 bench session with that chip and I didnt want to blow anything up from the start.
Hey thanx alot, my FX-57 rival....always wanted to say great job btw on that :D. 32m is really new to me and I don't have it down like the French OC'rs or Japanese do, but I am learning. Any tips from you guys is hugely appreciated :toast:Quote:
I am on bios 1004.
i'm stunned :eek: :cool: :cool: :cool: :cool: :cool: this is way cool man.....i'm extremely envious matey :DQuote:
in terms of straight OCs >>> nah mate just crank it down and give it all you've got :D
yes the affinity works with P965 boards well and so untick Core0
680i strangely works better with Core1 unticked LOL
i found that ~128 maxmem was fastest consistently on 1M and around 600 for 32M.............coppy wazza ain't that great on C2D or i haven't hit the sweet spot but ~5seconds is nothing to sneeze at anyway :)...............Before has some crazy 6GB file he uses but he hasn't mentioned he gains with it...i use ~2GB file
i was much better at AMD tweaks but the key here is RAM speed on P965 with 4-4-4-x maxed out and a few basic tweaks or if you have a chance to go with WS Pro board and max 3-3-3-x timings 1:1 there is nothing that competes....(well so far i haven't seen anyone attempt what you've done for tops scores :D P965+high CAS4)....but tweaks are a bit different on 975X chipset which i have no experience with at all
I'm going to go out on a limb and say if you apply the above along with a few reg tweaks and extra juice and speed on CPU....some records in SuperPI categories will go down..... :)
fingers crossed this CPU likes 1.95v and another 20C temps drop as you say :slobber:
pfft WTF am I doing telling KP how to bench LOL >> kicks my own arse hahah
You're welcome buddy :toast:Quote:
hehe FX-57 contest was ages ago; I still have the chip (it allows me to write ATM :rolleyes: )... It misses me the bravery for fighting with cold-bug; but I'm considering benching it again one day. :)
Is that 1004 bios better than others for X6800? 32M stability @5.2GHz is very good (and with both cores enable...)... okay you need the Right chip to do so, but on P965 it's pretty awesome even with it.
For fastest 32M times (may be 9m20s for you :D), copy-wazza is by far the most important tip with Luna theme. I'm using a big file to copy from the OS partition to the Spi partition prior to run spi.exe.
You know, spi.exe redundantly calls uxtheme.dll to write computations, manage the window, etc. so you need to have theme's service running along with Luna theme enable instead of Win Classic. Also, green olive or silver schemes are little bit better than blue one...
Then, I guess I'm not gonna teach you something there, but you have some registery keys that can be changed. BTW it remains me unclear which ones are actually used by the kernel.
Anyway; if you have questions, feel free to drop me a pm ;)
Updated. Sorry for the delay. I have definately not forgotten about this thread. Its flattering to see ppl join XS and their submissions here are their only posts.
Sorry but I stick with the 2GB, 965, 975, AM2 setups only. I stick by the idea that its too easy to hit 600MHz on 680I and RD600, so maybe the 700MHz thread is more for those guys ;)
Someone suggested 1T. If ppl break 600MHz, 1T then hell yes I want to see your posts here! but I suspect a dedicated Congratulations thread will be more appropriate!
CPU: E6850
M/B: Asus P5B-E Plus (C2)
Mem: TeamGroup PC8000 "Re-spd'd"
2.25v vdimm
http://web.telia.com/~u97102906/3.6ghz.600mhz.jpg
Dual
http://web.telia.com/~u97102906/dual...ghz.600mhz.jpg
