no mine is 68MOAG
no mine is 68MOAG
I didn't know that:) My bad...How's perform Pinto?Quote:
Originally Posted by pinto
Mine is a 68M0AG as well. No idea if there are any differences between that and 69M0AG like the P5W-DH 1.65v-1.85v change (there better not be!)
Dumo: Just so I know in advance - I presume from your PC Probe temperatures that this board doesn't read negative temperatures properly? Wonder why the P5B-Deluxe seems to be able to do it, but not this board?
Yes, PC Probe read it as -255...ie. 215-255 is -40C.
I think bios can only read up to -35C.
i got -60° in bios normaly, dind't go any lowerQuote:
Originally Posted by Dumo
I received mine the other day, just waiting for a few last pieces of my water cooling set up before I use the board.
Mines 69M0QG as well.
Mine is 68M0AG, too.
It also perform well as you guys.
69M0AG awaiting memory
Any help?Quote:
Originally Posted by N15M0
Installed my board. Past 350 FSB doesn't boot. Clockgen past 350 FSB in windows and it locks up. Help?
Manual
350
ddr2-700
auto
100 tried 105
33.33
disabled
disabled
2.1v
1.38v (it overvolts to 1.42, plenty for 3.7 Ghz)
1.4v
1.7v
auto
ram 4-4-4-12
Which bios are you using? 0022 seems to give the highest FSB with normal cooling, especially if you run single-core.
Using default BIOS 0116.
I fixed the problem by setting ram timings to auto, which sets 5-6-6-18, even though the ram is underclocked and likes to run 4-4-4-12.
It would only boot past 350 FSB using auto. I'll have to play with the ram.
Currently 415x9 1:1... priming 1.38v in bios, overvolt rocks :D
Under the memory timings section, set Read Delay to 7. That should help.
Thanks Sierra, i'll see if that helps me set manual timings.
Right now i kept it on auto mem timings, so the memory sucks... BUT...
I'm priming at 9x430 = 3.87 Ghz with 1.5v set in the BIOS, 1.52v in windows, not bad :)
I'll push for more FSB in a sec, i need over 4 Ghz benchable
http://img.photobucket.com/albums/v7.../Intel/3-5.jpg
edit: unfortunately read delay 7 didn't help. I can't get this board to boot at anything other than AUTO mem timings.
Another 68 here...Quote:
68m0ag1638xx
90-mbb520-goeay
Any ideia how it will perform? I'm gonna test it to see if it's good ;)
Absolut that is normally very good memory - so I'd hold out some hope for bios maturity to help you out some. Nice clocks though!
Nice board. Seems like its the one to look at
6700 stock cooler (waiting for the return of my mach2 from the mechanic :D )
p5w64 ws right out of "da" box
http://img83.imageshack.us/img83/8283/p5w64wsfv2.jpg
Can't wait to test it under ice ;)
My, that's alot of VGA slots...
:D This board is sometimes a bit tricky - but with some patience You can get success :slobber: :
http://img355.imageshack.us/img355/1...1m12562sv4.jpg
CPU on water, all other stock except Vdimm pencil mod. This is done with the insane CELLSHOCK PC8000 RAM at 2.71 Vdimm. :woot:
:toast:
does soft fsb work on this board?
ClockGen works for sure :)Quote:
Originally Posted by vanovich
:D Yes - but no need for. My 4,014Mhz is bootable..........;)Quote:
Originally Posted by [timko]
:toast:
If you drop your multi down to 8x, how much further can you push 1:1? :)
Howe much is Vdrop when in bios is set 1.7V ?
