Here's another vote for posting bios 0215:)
I'm told 0215 is the same as 0022, except no single core option.
'nuf pictures? nice tho :)s
Any links to this bios?Quote:
Originally Posted by sierra_bound
Thanks Sierra!
No link or upload ?? .... Is it that much of at secret ?
-----CB
:confused: Can't find it nowhere - what's up with the 0215...???
Yes, it does.Quote:
Originally Posted by Durzel
Nice to know. :) The main changes I mentioned are from 0209 to 0215.Quote:
I was not asked to not share this BIOS. I don't know if it is OK to post a link in this thread. I've sent some of you a PM. ;)
Ok, let's make a rule. If you get a beta/test bios and are not allowed to link/share it, then STFU about it. Looking at your screenies of amazing OCs on a bios the rest of us can't have is useless. How many of you would like to know how much I paid for my E6700 through the Intel EPP knowing you can't do the same?
I have 209 and 212, never saw 0022 or 215, links are here!
http://www.m7w.de/download/asus/p5w64ws/P5W64_0209.zip
http://www.m7w.de/download/asus/p5w64ws/P5W64_0212.zip
I take no responsability for blown boards or noobish use of bioses!!
OK, I can share:
http://rapidshare.de/files/34668447/...-0215.rar.html
Use it at your own risk!
lol sharing seems contageous today :D
Strange! I cannot get my sys to boot up with any multiplier other than 9.
I can change it within the bios but it loads as x09 all the time. Any1 have and idea as to whats going on?
watercooling anyone?Quote:
Originally Posted by NickS
heh
Originally Posted by MaSell
I'll void your warranty if you do them :P
after that what I saw I'm considering replacement my bad axe with this board, but other problem is that I sold all I got, 10pcs in 2 days :| and I don't know if next deliverty will be priced 200usd like those :(
You da-man merlin! Thanks again.Quote:
Vielen Dank! And much appreciated. Another vote for P5W64WS: I am using mine since a week, and clearly overclocks better than the P5B and 2 P5W-DH I have running. I get a full 100 Mhz more out an E6600 with the P5W64 than with the P5B.
The only issue I have is an obviously misreported vcore voltage. Setting the vcore to 1.400 in BIOS is shown as 1.480 in BIOS hardware monitor and Probe.
Wow~~ Thanks a lot, dude.:toast:Quote:
I for one will read about bios's that aren't public. This is XS. Often if you ask someone they'll share if they can. If they can't, them's the breaks :)
Less worry! More benching!
I check 0022 and 0215 BIOS again. The two Bios are all the same.
One is official BIOS, another is beta. They only are different from name.
Thanks for checking.:)Quote:
Originally Posted by AndreYang
I'm not going to say that PC Probe is 100% accurate, but it's not a "misreport," you are witnessing the overvolting that this motherboard has, instead of Vdroop. You get more actual volts than set in the BIOS, instead of way less.Quote:
Originally Posted by chainbolt
Nice work! What BIOS are you using there? :DQuote:
I have no idea what BIOS I should be using on this board really... I have 0209 installed at the moment, 0116 is still the only official one listed on Asus site which doesn't have multiplier select or the various memory options.
Then there's 0022, 0212 and 0215....
Argh! Help!
I'm using 0022 at the moment. 0209 isn't bad either. When the weather gets a little cooler, I might be able to run 32M at 4100MHz on air. Ambient temp is still too high. I could pump air-conditioned air onto the board and go over 4.1GHz easily. But I want a more realistic air result.
You got one nice cpu there :) And yes I agree with sticking to what is real. But the colder season approaches...
