I've had two DH's and now the ws-pro. The ws-pro is a better board all around.
:D You keep me hopes high. :clap:Quote:
Originally Posted by xgman
Looking at the BIOS it looks like the WS-PRO only supports 1.20v on the ICH, whereas the P5W-DH supports up to 1.40v? Is that likely to cause problems?
:D Not so far.
http://www.xtremesystems.org/forums/...d.php?t=115221
:woot:
Could you (or anyone) please state the factors that you think make the ws-pro better???
Other than having PCI-X and higher MCH voltage?
I also have had a DH and now a ws-pro. I have read that the DH may run cooler than the ws-pro.
Andrew
I`m thinking of selling my P5W DH and get an P5WDG2 Pro...my board has the FSB limit @ 425V and the VDROP is really annoying...is this worth or not?
Regards,
Primoz
maybe I can tell you by the weekend I have one coming soon..
regards
Raja
I think DG2 retail is a better board (compared to 64 retail)
Considering the price difference, that's good :DQuote:
Again, any real specifics as to why it is?
Other than "gut reaction", are there any better components, more capacitors, etc on it?
Andrew
:D The ws-pro is a better board all around :
http://img156.imageshack.us/img156/391/sp1m3960ka5.jpg
:woot:
I would think the new rev of the DH with higher Vmch may have helped. I have only used the first version of the DH and had three of them and they all gave me some degree of trouble. The WS-pro just handles better and seems a little more robust to me. I like the 8 phase power as well. As far as the caps etc. I haven't doen a compare. I don't use the PCI-X, so that doesn't figure in for me. At the time I got the DH for $300, it wasn't that much more than the DH was selling for in any case. And by the way, all the conroe boards run hot when overclocked. That's one reason I finally bit the bullet and changed over to phase cooling. ;)Quote:
Originally Posted by aamsel
I thought that the DH also had the 8 phase power???
Don't get me wrong, I already have a WS-Pro, just second-guessing myself, as usual.
Andrew
:( We need very urgently a new BIOS with the ability to lower the muti for this board - P5W DH & the new 64-WS PRO can do.
Right now all DG2-WS PRO user are kicked in the a$$......... :stick:
Bios 0005:
Link
big thx@camouflage
file deleted... something went wrong...
After updating to BIOS 0005, my RAID 0 set was not found.Quote:
Originally Posted by Schlingel
I also changed some settings, saved and exit but the PC didn´t restart. I had to do a chassi powerdown.
One thing I noticed before going back to BIOS 0307, was the CPU and MB temps in BIOS. Much lower than with 0307.
No problem to revert to 0307 and system is running stable.
Must have been a bad flash. Raid0 works fine for me with the 0005. I used AsusUpdate. Make sure you click the box that asks if you want to clear CMOS on restart.
Geek
You´re right, thanks!Quote:
Originally Posted by fishingeek
After reflashing via Asus Update, it´s OK.
The first time I used Asus EZ Flash.
With this BIOS AiBooster and Intel Thermal Analysis Tool are showing the same CPU temps.
Multiplier is now unlocked from 6 to 20.
Noticed the following:
CPU-Z reports Core 2 Duo.
Intel Processor ID reports Core 2 Extreme.
With BIOS 0307 CPU-Z reports Core 2 Extreme.
http://max.ownit.nu/ExtremeDuo.PNG
http://max.ownit.nu/IntelTAT35CPUZ.png
:confused: Anyone knows the measure point & resistor to pencil for a Vdimm pencil mod on this board???
Anyone here have Asus "AISuite" working with the ws-pro?
AISuite only worked on ASUS 965 chip.
i find the 0005 bios more robust bios than 0004...Quote:
Originally Posted by Simon
i did have a few boot issues but i made an adjustment to the memory timings and i increased voltages to solve the problem at the moment...
with the newer bios, i was able to move up another 30 Mhz on the FSB...first time i was able to hit 500 MHz memory speed.
Originally Posted by AndreYang
ohhh!! ;) How about suggesting a new interface for aibooster for the rest of us. Aibooster looks like yellow submarine for todlers. :rolleyes:
Originally Posted by Ace-a-Rue
I like it as well. Hope Asus releases it soon.
waaa, waaa!:D :D :DQuote:
