I'm just getting my feet wet with the overclocking. I'm doing it all in the BIOS for now... no memset or setfsb for me.
CPU: E6600 Retail OEM (not lapped)
Mobo: P5W DH Deluxe (BIOS 1101)
Ram: G.Skill 2GB HZ 4-4-4-12
CPU Cooling: Scythe Ninja+ with Coolaboratory Liquid Pro (not lapped)
Mobo Cooling: AS3 on SB with cover removed and AS3 on NB with Swiftech MCX-159CU. No extra fans anywhere.
Case: Lian Li v1200b (case closed, not using the card slot exhaust fan or cpu fan duct because neither fit. My SCSI card blocks the card slot cooler from going in and my ninja blocks the cpu fan duct.)
Right now I am running at 340x9, fsb:dram 4:5, DDR2-850mhz (425.6mhz)
for a CPU clock speed of 3064mhz. All BIOS settings are stock except for manual ram timings of 4-4-4-12 and FSB of 340.
Ambient: 23C
Orthos large FFT for 6 hours:
Load Temperatures:
Core Temp: 58C (fluctuates between 54 and 59 but mostly stays at 58)
PC Probe: 41C
Idle Temperatures 15 minutes or so after stopping Orthos:
Core Temp: 44C - 50C fluctuating
PC Probe: 32C
When booting up after leaving the machine off for 6+ hours PC Probe reads like 25 or 26C at idle. Bear in mind that I use stock BIOS settings which means that it throttles back voltage and multiplier at idle so I'm only running at like 2ghz at idle. My temperature readings go down VERY fast after a short stress test but after 6 hours of Orthos it takes a bit more time ;).
Last night I tried for a few hours to get 380x9 stable but I could not acheive it. I tried up to 1.475 vCore, 1.65 vMCH and 1:1 with SPD timings but Orthos large FFT would always throw an error after roughly 5 minutes. Increasing vMCH from stock to 1.60 took me from an almost instant error in Orthos to many minutes straight before an error. I think if I keep increasing vCore I may see more stability but I think I'm going to give up on 3.4. Tonight I'm going to try for 360x9 @ 1.45 vCore and other voltages stock with ram at 1:1 and 4-4-4-12 or better timings. I hope I can hit cas3 at this memory speed with a little vDIMM and vMCH :p:.
Edit: I raised vCore in the BIOS to 1.500 (with 1.60 vMCH) and I am now 4 hour Orthos large fft stable at 380x9 and 4-4-4-12! My new core temp load temperature is 67-69C though :eek:. After seeing the stability increase of going to 1.500 vCore I tried going back to stock vMCH and it bombed out pretty fast :(.
Edit Edit: I reduced my FSB to 378 and vMCH to Auto and I am now 7.5 hour Orthos large fft stable super cerial.
-JWM
