Originally posted by OPPAINTER
You don't need to cut the pin, there is a small resister in the trace you can just take off, this gives you a cut in the trace. Then do the 10 ohm and 100 ohm VR combo.
I'm thinking now that all you really need to do is solder a 100 ohm VR to the Pin side of the mobos resister without taking it off the board.
OPP
Yeah, I don't understand this... I'm fairly new to vmods. Do you have a pic of the resistor that you take off? Then where exactly do you solder the wires to? The only vmod I've done is the KX7 mods... Also, I only have 500 Ohms and up VRs, and no fixed resistors... Can I just use a 500 Ohm VR, set it at 100 and lower it from there? And do I really need the 10 Ohm fixed resistor?
