Originally Posted by DEVIL_DK
tests to make a cmos and rebot
can you guys report in about issues like vcore droop FSB limitations and such you know the usual asus bullcrap.
vcore droop is something i absolutely hate. i need to see if its bad or not.
Wow, 4Ghz on air !?? What's up with that? Tom's Hardware and CPU Magazine both had to run water cooling to get this chip to that level.Quote:
Originally Posted by simonmaltby
So is it true that you can't set the FSB to lower than 200MHz?
Congrats on your 805's stellar performance:toast: . Give a few more details on your hardware setup (edit: I see you posted your setup in your sig).
Not true at all. goes from 100 to 450 or anywhere inbetweenQuote:
Originally Posted by hukhound
:D Thanks for clearing that up.Quote:
Simonmaltby,
Have you tried running Prime95 at 4GHz?
I dont bother with prime. Its a working machine. I run it as my web developemnt workstation / server all day, its running Server 2003, SQL Server 2005, IIS, coldfusion server plus music.Quote:
It has run without a glitch for 2 full days at 4ghz of general use.... i would say thats as good as prime.
Just running 32M SuperPi to double check seeing as you ask :)
Question: Does this board support Crossfire only? Can a 7950GX2 run on it?
Is ASUS planning on releasing a similar SLI ready Motherboard?
Makes sense. I backed my 850 down to 3.4GHz because it's the highest setting that would pass Prime. I just hate buggy systems, so I'm leary to push it further.Quote:
Does Super Pi test for processor errors? I thought it was just a speed benchmark.
Originally Posted by Lestat
OK, I took some measurements of the vcore voltage:
set in bios: 1.6v
AI Booster: 1.56-1.58v idle
dmm idle: 1.585-1.593v
dmm load: 1.559-1.560v
so thats a .026-.033v vcore voltage drop as read via dmm
Much better than past asus intel boards I have had, but not perfect.
New BIOS is supposed to address that issue:Quote:
http://www.iamxtreme.net/andre/P5W-DH-0602.rar
If VCore is showing only Auto, try clearing the CMOS. This should fix the problem.
For anyone getting this board, I recommend clearing the CMOS before doing anything else.
Originally Posted by sierra_bound
New Bios already fixed this problem.
yeah which one, and links??
oh thanx, and should i do afudos or ez flash. i will recieve this board on monday, so ...
new review here http://www.hardwarezone.com/articles...?cid=1&id=1958
"the board consistently performed slightly below the older P5WD2-E Premium in terms of CPU and memory subsystem, but it did come out ahead in graphics and game tests" ...a couple % below P5WD2-E
eh true. but its got one thing that d2 doesn't (at least not yet), c2d support aha. d2's got nothing on the dhQuote:
Originally Posted by gazzoom
I'm getting an Error 404: Not Found for this.Quote:
Originally Posted by webwilli
Alternative link...I've just downloaded and not yet tested it, though:)Quote:
Originally Posted by DragonOrta
http://p5wdh.de/downloads/asus/bios/p5wdh602.zip
That's good enough for me. Thanks.Quote:
Originally Posted by kyosen
Dragon, did you get an ES chip?
Yeah, it's one of the stepping 4, I think. I bought it about 3 or 4 days before AndreYang started selling his stepping 5s.
I ordered the Asus today.. Ill pickup a retail 6600 when they become avail since its only about 4 weeks away. Lemme know how your rosetta output is please.
I've used a couple of older BIOS files where this was never an issue. ;) And it only takes about ten seconds to clear the CMOS, even if it were an issue.Quote:
Originally Posted by AndreYang
