Originally posted by MnM
Thanks to you guys I have finished this mod.
I replaced the 0Ohm resistor with a 331Ohm one (IC7-G).
It works perfect. At 2.55 selected in bios it will actually give me 2.75. Didnt try any higher yet.
Funny thing is this.
I have done one motherboard first and it worked perfect.
Then I did my friend's one. He would get a blank screen and no post. We replaced the resistor (the 331Ohm one) with a new one, thinking we might have given it too much heat. Same result. No display at all. What I have done then, is I shorted the 331Ohm resistor with some twizers therefore giving it a 0Ohm value.
I got post. I removed the twizers not post.
In the end what I have done is I put another resistor (331Ohm) ON TOP of the 331Ohm already on the motherboard. I solder it in parallel. We turn the PC on - POST!!!!
Now with this mod, he gets only half the voltage from the normal mod eg. 2.55 selected in bios actually gives him 2.67 real volts.
He was happy with it as he already thought he had to spen $$ for a new motherboard. Plus in the end he still gets more than the 2.8 limit.
So 2 identical boards, two identical mods but only one of them worked. I think the components used on the boards and their tolerances play a big part in modding the vdimm. I am now sure that if I had a 400-450Ohm resistor around and would have actually solder it to my friends board will have worked giving him a bit better than just 0.1 increase over the value selected in bios.
Maybe this info can help the guys who cant get a post after the board has been modded. Try solding one to the motherboard and one on top of the resistor. At least you will get more than the defualt max voltage in the end.
